tailgate locked
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoan, Nov 30, 2013.
  1. Nov 30, 2013 at 8:26 PM
    KALRODJ
    KALRODJ Member
    Paul
    On either end of the tailgate, my truck has a gap at the top, going down about 1". Maybe you can get a coat hanger in there to unlatch the cover?
  2. Nov 30, 2013 at 8:29 PM
    Tacoan
    Tacoan [OP] Yes I know there's a search bar…….
    US of A
    2014 Toyota Tundra
    King shocks, eliminated front sway bar
    yea that's my best course of action, gonna try tomorrow, thanks for the response
  3. Nov 30, 2013 at 8:49 PM
    thebrick
    thebrick Well-Known Member
    Frontrange
    06 2.7L Base
    fox 2.0 remote res toytec UCA all pro add a leaf bilstein 5100 all pro standard bumper hid kit
    What kind of warranty does your tonneau have? If its a good warranty, I'd do the dishonest thing and bust/cut it open. You know, make it look like an accident.
  4. Nov 30, 2013 at 8:51 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Hmm. Fraud. Nice.
  5. Nov 30, 2013 at 8:54 PM
    Tacoan
    US of A
    2014 Toyota Tundra
    Ummm agreed! Won't try that one
  6. Nov 30, 2013 at 9:00 PM
    169.254.255.201
    169.254.255.201 Well-Known Member
    Interwebs
    TW might seem like a bunch of people who would be dishonest, but truthfully we aren't that way.
    For example.. The thread with ASE tech, who instead of using the customers requested Armsoil oil, used the cheapo oil and pocketed the armsoil oil himself.
    I'm out of here before this gets to nasty though. ..
  7. Nov 30, 2013 at 9:47 PM
    clearcreek
    clearcreek New Member
    Shane
    Western NC USA
    2011 Sr5 Access Cab 4x4
    If the latch parts can be replaced, drive a wedge under the top (only need 1/16" - 1/8") and reach in with a hacksaw blade, or sawsall and cut the bolt. A metal cutting blade on an oscilating flush cut tool may have enough reach. A body shop may have a cutting tool that will reach.
    Shane
  8. Nov 30, 2013 at 10:09 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    For real. Not cool. We don't roll like that.
  9. Nov 30, 2013 at 10:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    we generally remove people from the site that promote fraudulent activities.
  10. Nov 30, 2013 at 11:05 PM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    I have the same tonneau on my truck. I would give Extang a call. They may have had some experience with a similar situation.
    Good luck!
  11. Nov 30, 2013 at 11:29 PM
    JTyfz450
    JTyfz450 Well-Known Member
    Jeryck
    SoCal
    2012 TRD Sport DCSB MGM
    Had a similar thing happen to me. When I installed the Pop and Lock I forgot to put the rods back in place so the latch wouldn't work. I got my little brother to stick his tiny arm under the side of the cover and he was able to unlatch the cover. I'm sure you can do the same. The pull up on the side of the cover as much as you can to allow an arm to get through and unlock it. It's worth a try.
    ...Those Velcro strips will scratch your arm so be careful =).
  12. Nov 30, 2013 at 11:32 PM
    thebrick
    Frontrange
    06 2.7L Base
    Wasn't funny. Got it. Apologies.
  13. Nov 30, 2013 at 11:34 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Good call, I can't imagine this is the first time this has happened..or they may just give him the go-ahead to cut it? Doubt it but never know
  14. Dec 1, 2013 at 4:10 AM
    Hot2na
    Hot2na Well-Known Member
    Call a locksmith....they usually have unconventional methods of dealing with stuff like this ....
  15. Dec 1, 2013 at 4:30 AM
    #35
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    If you put the metal plate back on the tailgate...sounds like your screwed TBO. There are 12 screws iirc and don't remember any space to slide a hanger. Unless I'm missing something here...I'm new to the truck scene so I could be wrong.
    Sounds like this is going to be a pain...sounds like either way your gonna have to break something to get in.
  16. Dec 1, 2013 at 4:49 AM
    #36
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    Locksmith will not help, It's not locked. The mechanism/rod or whatever is not connected to the pop and lock so the tailgate can't be released.
  17. Dec 1, 2013 at 4:58 AM
    #37
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Does your bed have the storage boxes in the sides? Can you possibly pop them out into the bed and then use those to reach up with a coat hanger type tool and pop the cover latches?
  18. Dec 1, 2013 at 5:06 AM
    #38
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    I'm going to go back to the idea of access through the bed side pockets.
    If they were able to be removed from under the bed somehow, it might be possible to get something up in there to unlatch one corner of the bed cover...
    I haven't looked at mine but it might be possible to slot the end of the bolts under the bed and turn them out from underneath.
  19. Dec 1, 2013 at 6:45 AM
    #39
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    This sucks.. I just repaired mine because i noticed it was not latching right.. i opened it up and fixed the tabs before it broke fully... Unfortunately i dont know what to do with this.. If a lock smith wouldnt be able to fix it for ya and the coat hanger doesnt and no reach from the pockets... Also does your bed have a small gap in the bottom where stuff like water can drain out.. i have one in the corner of my bed the driver side maybe get a coat hanger or something up in there.. If none of this works.... The less expensive thing i would think of doing would be drill your Poplock out. i know it sucks but better to destroy a poplock handle then destroy your cover, you should then be able to reach in and grab the metal wires to open the tailgate.. Good luck
  20. Dec 1, 2013 at 6:45 AM
    #40
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    He would have to unscrew all the screws first on the tailgate. I think it would be pretty hard if not impossible to do that through those storage boxes. I'm on the same idea that you would have to break your pop and lock.
