Tailgate pad AND campershell?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NoMoreMrRiceGuy, Sep 23, 2013.
  1. Sep 23, 2013 at 10:40 PM
    NoMoreMrRiceGuy
    NoMoreMrRiceGuy [OP] Well-Known Member
    jonathan
    San Anlsemo, CA
    2011 DCLB 4x4, 1997 240sx w/1JZ swap
    Thinking of taking a tacoma to the bike park and camping, i wanna shuttle my bike on a tailgate pad, but be able to sleep in the bed of my truck with a campershell for nice warmer sleep, can you put a campershell AND a tail gate pad on at the same time?
  2. Sep 23, 2013 at 10:50 PM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Bestop Soft Top.
  3. Sep 24, 2013 at 6:58 AM
    NoMoreMrRiceGuy
    jonathan
    San Anlsemo, CA
    that would work with both?
  4. Sep 24, 2013 at 7:01 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    It should because the back window is a flap so you can roll it up and out of the way and put the tailgate pad down.
  5. Sep 24, 2013 at 9:58 AM
    Nixinus
    Oregon
    2010 4x4
    Yes, the whole top folds down in a couple minutes while you are using the bed or you can just remove the back window and use the pad for your bicycle. Its a versatile top that I've been using to camp out of for years now.
  6. Sep 24, 2013 at 3:47 PM
    NoMoreMrRiceGuy
    jonathan
    San Anlsemo, CA
    Oh okay i see, so its versatile enough to put in the bed and switch out?
  7. Sep 24, 2013 at 4:03 PM
    Nixinus
    Oregon
    2010 4x4
    You don't have to take it off. It folds down by the cab.
  8. May 18, 2014 at 3:54 PM
    Ralston
    Ralston Well-Known Member
    High in the Rockies
    Super White - 4x4 - TRD Off Road
    what is a tailgate pad?
  9. May 18, 2014 at 10:46 PM
    NoSilverBullet
    NoSilverBullet N60 member
    Northern Canada
    2012 AC 2.7 MT 4wd
    Old Man Emu suspension: 884x coils, Dakar leaf pack, Nitrocharger Sport shocks. Cruisin Offroad bolt-on sliders. Relentless Fabrication aluminum front and mid skid plates + steel transfer case skid. SnugTop Hi-Liner "Sportsman" canopy. Hella Rallye 4000i Xenon (flood beam).
    example:
  10. May 19, 2014 at 1:39 AM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    This may be helpful to you.
    I can fit two 29ers in the bed of my truck under the camper shell. It's great because I can lock them in there safely! I could easily sleep next to my bike while it was in there. It takes some crawling around to get into the camper shell to put the bike on the fork mount. That's not a problem for me, but if you were doing lots of shuttling in one day, you could still use a tailgate pad and drive with the camper shell open. The gas-struts are very strong and it is okay to leave it open while driving.
    I found my camper for $800 on Craigslist, which is only a little more than a soft topper or bestop and is soooo great. It is water proof, holds my bikes securely, I could camp in it nicely, and it locks from the inside for added security while camping. I made the bracket for the dropped fork mounts with parts from home depot. No special fabricating involved.
    You could also put the fork mounts on the side of the bed closer to the tailgate which would allow you to put the bike in without crawling into the bed.
    PM me if you have any questions!
    MyToyTaco likes this.
  11. May 19, 2014 at 6:07 AM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    I use a pad with my canopy. I can't throw my bikes in with the tailgate up, but if I open the tailgate and leave the front tire over the edge they do fit once it's closed.
  12. May 19, 2014 at 7:40 AM
    4x4fiend
    4x4fiend Member
    I don't have a topper so just thinking out loud, but it might not be too hard to make the topper door hinges quick connect style. Then just pop the door off and wrap in a blanket at the front of the bed when your shuttling, pop er on at night to sleep.
    Or maybe remove it all together and get a canvas shop to sew up a best top softtop-like flap you could bolt into the original door hinges, with some magnets or snaps to keep it closed. Then you've got the best of both worlds, hardtop with roll up back door
  13. May 19, 2014 at 7:47 AM
    Speck
    Speck Well-Known Member
    Tejas
    07 2.7 4x4
    I think the greater challenge is going to be getting the bikes on the tailgate pad while you have a shell. Usually I'm assuming that you drop them down on the tailgate...but you won't have the clearance with a shell.
    Why not just put the bikes inside? I put two in my shell all the time, I don't even take a wheel off.
    When I do haul long stuff (wood) with my shell though, I either just leave the rear window up if just going slowly, or tie it so it comes down a bit but doesn't touch the stuff.
  14. May 19, 2014 at 7:59 AM
    IanN
    IanN Well-Known Member
    Ian
    Medford, OR
    2013 DCLB TRD Sport
    TRD exhaust
    Get a Softopper so you can roll it back! I have a pad on the back of my truck for mtb too.
  15. Aug 2, 2018 at 9:13 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I'm thinking about a similar option but maybe putting the fork mount in the rear for easier access. Is there a reason you didnt do it that way? I'm also wondering how much side-to-side motion there is; is there a risk of your bar end hitting the glass?
