Tailgate power lock - OEM or Pop & Lock?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nutmeg1281, Jun 15, 2020.
  1. Jun 16, 2020 at 8:04 AM
    Nutmeg1281
    Nutmeg1281 [OP] Member
    2018 White Tacoma TRD Sport
    Thank you all so much!
    deusxanime likes this.
  2. Jun 16, 2020 at 8:14 AM
    Travis17
    Travis17 Well-Known Member
    Travis
    2017 Tacoma Limited
    I installed a pop-in-lock years ago before the OEM was available and it has worked well. Except that eventually I had to replace the lock because the pop-in-lock eventually broke off the connection point. I don’t know if the OEM version has solved this problem or not.
    DawgDaddy likes this.
  3. Jun 16, 2020 at 8:15 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
  4. Jun 16, 2020 at 8:19 AM
    Hatfieco05
    Hatfieco05 Well-Known Member
    Portland, OR
    2020 DCLB TRD Off-Road Premium
    Amazon sells the oem unlock for 165. Both long and short bed in stock.
  5. Jun 16, 2020 at 8:27 AM
    Shellshock
    Iowa
    it is $140 with free shipping direct from toyota
  6. Jun 16, 2020 at 8:46 AM
    Hatfieco05
    Portland, OR
    Shows 169 on Toyota.parts and the Amazon shipping is prime. Unless I’m missing a discount code?
  7. Jun 16, 2020 at 11:47 AM
    Nutmeg1281
    Thank you everyone! I was able to find one from parts.toyota.com for $150 with free shipping!
  8. Jun 16, 2020 at 11:50 AM
    Shellshock
    Iowa
    thats MSRP. Select a dealer and it'll be discounted.
  9. Jun 16, 2020 at 11:53 AM
    rcarpio19
    rcarpio19 Well-Known Member
    Ronnie
    2019 Cement Tacoma TRD OR
    daveeasa likes this.
  10. Jun 22, 2020 at 4:46 PM
    daveeasa
    David
    PNW
    Anyone got a link to some install instructions for the OEM lock? Just follow the Pock & Lock instructions? It's super obvious and connection in the passenger kick panel so no instructions needed?
    Got mine today, OEM kit looks fantastic, excited for this.
  11. Jun 22, 2020 at 4:48 PM
    ChrisIz
    ChrisIz Well-Known Member
    Texas
    2023 TRD Off-road
  12. Jul 5, 2020 at 10:13 PM
    daveeasa
    David
    PNW
    Got the body harness installed tonight. Lo and behold, it looks to me like someone designed this with excellent attention to detail but the finished product came out with the tailgate quick release connector reversed. The instructions say to zip tie the tailgate connector which just seems wrong because the camera connector is not secured, thus allowing quick and easy tailgate removal. I’m guessing the zip tie approach is at least easier to remove and replace than if you were to mount the tailgate connector on the spot perfectly made for it next to the camera connector. Nuts!
    I’m almost tempted to cut and re-splice the connectors on the correct ends. That way would allow proper rapid tailgate removal while ensuring the body plugs are secured to the vehicle.
    I’m case it’s not clear, the white plugs are for the camera, harness tape removed. The black plugs are for the OEM lock. The black left side and white right side go to the tailgate while the black right side and white left side go to the interior along the frame.
    EDIT: I think I've decided to do 2 mods to this to make it better:
    1. Reverse the connectors for the body to tailgate connection, thus allowing the body harness connector to sit properly on the white plastic mounting tab next to the camera connector.
    2. Untape the factory backup camera loom and insert the tailgate lock wire for the portion of the loom before it exits the tailgate to after it enters the frame. Thus I'll only have one loom for that run instead of 2 zip-tied together. Since I'm cutting off the connector already for 1, this should be a pretty easy process. I'll have a small Y at the body side and probably just go harness tape inside the tailgate since that's already protected. If this works, I won't need the new double-grommets and I might even be able to do it all without touching any of that, if the wires are stiff enough to fish through the loom on their own.
  13. Jul 6, 2020 at 12:15 PM
    Sotex13
    Sotex13 "Do it live"
    Magnetic Gray 2018 TRD OFF ROAD DCSB 4X4
    Installed pop n lock about 2 years ago and no regrets at all. Super easy install either way you go it will be good
  14. Sep 30, 2020 at 8:54 PM
    fryrice
    fryrice Well-Known Member
    MA
    2020 MG Access Cab SR w/ SX pkg
    Anyone know if the access cab is long bed or short bed part #?
  15. Sep 30, 2020 at 9:07 PM
    #35
    daveeasa
    David
    PNW
    I assume shortbed since same wheelbase and same front seat. The part in the middle is all along the frame rail.
    fryrice[QUOTED] likes this.
  16. Sep 30, 2020 at 11:22 PM
    #36
    Afilao
    Afilao Tacoma Driver
    SoCal
    ‘18 MGM DCSB Off-Road 6MT
    DIY! Quieter than OEM and Pop n Lock. Also waaaaaaay cheaper! :cool:
    deusxanime and daveeasa like this.
  17. Oct 1, 2020 at 5:42 AM
    #37
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    Check out my video on how I installed a PopNLock on my 2019. By the way, the OEM IS a PopNLock. Here is the link:
    https://www.youtube.com/watch?v=9qeKhgnc3UI
    MacMan67 likes this.
  18. Oct 1, 2020 at 6:36 AM
    #38
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    It used to just be a rebadged Pop-n-lock until a year or two ago and then they actually came out with their own solution/kit.
  19. Oct 1, 2020 at 6:43 AM
    #39
    Dubrxsti
    Dubrxsti Well-Known Member
    Ty
    2020 Cement TRD Off-Road
    I used this same video, only place a got hung up is for some reason I thought He was accessing it from the rear passenger seat. Once I looked under the truck I realized that it was the front passenger seat.
  20. Oct 1, 2020 at 11:55 AM
    #40
    oogielaflick
    Keith
    Yes, if you look at the thumbnail I used, it actually shows the official Toyota part number on the popnlock box! Out of curiosity, I wonder if they still use the same part number if it is their own lock system?
