Tailgate problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elena619, Dec 1, 2012.
  1. Dec 1, 2012 at 12:30 PM
    elena619
    elena619 [OP] Well-Known Member
    elena
    Albuquerque, NM and San Diego, CA
    06 Prerunner TRD
    2nd exhaust bhlm solar led halo headlights blacked out tail lights and 3rd brake light
    So I'm wanting to black out my tail lights and my tailgate is jammed. I want to take it off just to do this if its an easy process. I realllllly don't wanna have to go to Toyota for them to do it. The latch is stuck and the handle doesn't work at all anymore. Is this an easy fix? Or should I take it in?
  2. Dec 1, 2012 at 12:41 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    The side latches might be rusted closed. Try some penetration oil sprayed with it's straw to get into the left and right latches... handle mechanism too.
    Give it a bit of time to soak through.
  3. Dec 1, 2012 at 12:47 PM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    And if that doesnt work take of the cover on the inside of the tailgate, if it has the plastic liner your going to need Torx socket to take that off and then after you take the cover off there's like nine or so screws you have to take out and your golden. You will see all the guts of the door latch, spray it down with WD-40 or any other lubricant like WD. it should come free.
  4. Dec 1, 2012 at 1:31 PM
    File IFR
    Central MA
    Good answer, I was wondering if it can be taken off while closed... I thought (without looking at it) it would have been captured by the sides.
    Cool
  5. Dec 1, 2012 at 1:57 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I had to do this I got rear ended couldn't open my tail gate everything was bent inside. It should be easy for the op if the tailgate isnt damaged. There a possibility that something came loose inside
