Tailgate Reinforcement
Discussion in '1st Gen. Tacomas (1995-2004)' started by AKsavanaman, Feb 27, 2015.
  1. Feb 27, 2015 at 12:53 PM
    AKsavanaman
    AKsavanaman [OP] Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
    So I bought a a replacement Tailgate as mine was all bent to hell and wouldn't close properly anymore. Just decided to bedliner the enitre thing rather than deal with trying to paintmatch (although my truck's black so it wouldn't be too hard).
    Anyways, I purchased a piece of diamond plate to reinforce the new tailgate but I'm stumped at how I can fasten the piece so that I can remove it readily. any one have any ideas. I've played around with the thought of predrilling all my mounting holses and then somehow "gluing" barrel nuts in place on the the tailgate with the lip of the nut on the inside... any better options? I didn't want to use self drilling metal screws as I'm sure they would rattle loose over time. Input would be appreciated! Thanks in advance!
    AK
  2. Feb 27, 2015 at 1:22 PM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    You could use the self tapping screws in conjunction with an epoxy to keep the screws from 'rattling loose.'
    Just my .02.
    Why would you want to readily remove it?
  3. Feb 27, 2015 at 1:35 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    I think relentless fab makes a tailgate protector, might want to check out his design and see if you can make something similar.
  4. Feb 27, 2015 at 2:25 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    you can use rivnuts.
