Tailgate seal not sticking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trd taco guy, May 1, 2010.
  1. May 1, 2010 at 10:39 AM
    trd taco guy
    trd taco guy [OP] Well-Known Member
    Rob
    09 tacoma trd sport
    So I finally got around to installing my tailgate seal now that the weather is getting warmer but after a few weeks the lower part isn't sticking. So I was wonderng if there is any adhesive or some sort of caulk that you guys would recomend to hold the rubber to the composit bed?
  2. May 2, 2010 at 8:23 AM
    spp
    spp OC, Kalifornia
    OC California
    3M weather strip adhesive? Auto parts stores should have it.
  3. May 2, 2010 at 8:28 AM
    plinian
    plinian Member
    Kansas
    2010 DC Off-road
    A.R.E. CX shell w/Yakima rack
    On a related note, does anyone recommend any particular brand of tailgate seal over another? I just put a topper on my truck and would like to seal the tailgates as best as possible also.
  4. May 2, 2010 at 8:29 AM
    PreRunner
    PreRunner Well-Known Member
    Access cover, yes?
    Email eallen@agricover.com with your situation, serial number (black and white label on rear bar), and mailing address. He will suggest you rough up the area and remove the sheen with a scotch brite pad. You will suggest he sends you a new seal under warranty. I will suggest you spread a thin coat of clear silicone on adhesive prior to applying new seal.
