Tailgate steal attempt
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Franciscotaco2016, Mar 29, 2022.
  1. Mar 29, 2022 at 10:39 AM
    #41
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Solder it. Easy peasy. When I put on my C4 bumper I cut the back up cam off and ran it out to the swing out tire mount. Soldered it and have never had an issue. That was almost two years ago. Just use some shrinkwrap and electrical tape, you should be good to go.
  2. Mar 29, 2022 at 10:44 AM
    #42
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    Oddly enough, it doesn't sound too insane to me, because it is not just the wiring harness, but the labor to replace it. It is not exactly "hanging down" where you just unplug the old ends and plug in the new harness. However, that being said, I had something similar happen with my old 1996 Tacoma, in that some lowlife unscrewed my right rear taillight assembly and took it. However, instead of being nice and just unplugging the wiring harness, they cut it! I had a similar response from the dealer, regarding getting a new wiring harness. So, I just went to my local hardware store, and bought some "butt ends", which are basically wiring connectors where you simply insert the wire into each end and crimp it. Much better than the old twist on wire connectors. But since they had taken the actual plug, what I did was to also buy some wire plugs that fit onto the new light assembly, and some short sections of appropriate electrical wire, then attached the butt ends and connected them to the connectors I got for the actual back of the light. Plugged everything in and it was all working when i sold the truck in 2019. Probably the hardest part was actually figuring out which wire went to the taillight, brake light, turn signal and reverse lights! I had to get my neighbor to come over and hit the turn signals, brake lights, and reverse lights, etc, to make sure I had the wires plugged correctly. So that actually took more time than anything else. But the whole thing cost me less than $10, with all the connectors and short pieces of wire, along with about $75 for a replacement taillight assembly. In your case, you just need the connectors. Easy fix for less than a couple of dollars.
  3. Mar 29, 2022 at 10:48 AM
    #43
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Didn't read all the replies but any reputable shop will fix those wires for cheap. No problem. No need for a new harness.
    kahanabob likes this.
  4. Mar 29, 2022 at 10:59 AM
    #44
    alexh
    alexh Well-Known Member
    1998 TRD
    Good advice, I also use marine grade wire and heatshrink. As you said the marine grade heat shrink has glue inside of it.
    Whatever you do, IMO do not buy wire from the chain auto parts store. I did that once and the insulation is so soft it wore through very fast.
    Another tip is that if you ever use electrical tape on your vehicle, get the pro grade that comes in a plastic container. Once on your literally cannot peel it off. With the cheap stuff, you are lucky if it holds at all, never mind 10 years in a hot, dirty and oily environment.
    Quality definitely matters with electrical.
    Malvolio and whatstcp like this.
  5. Mar 29, 2022 at 11:16 AM
    #45
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    If worse comes to worse can't he just buy another locking tailgate handle with a camera in it and wire that up himself?
  6. Mar 29, 2022 at 12:10 PM
    #46
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    Comprehensive still shows a hit on your insurance. Nothing super bad but stilll something. I was hit by a car on my bike. She had insurance but because of court and delays and waiting for her insurance to pay out after all my rehab, my insurance covered all bills. They said its part of the comprehensive stuff. Fast forward a few years later when I added a 3rd car to my insurance, it showed the crash. Insurance said yes you payed nothing and the other ladys insurance paid all bills at the end of the day but it still shows up that a clam was put in. So ya he can use the comprehensive, but at the end of the day depending on the company, it can hit him in a negative way for something that can be done at a shop. The insurance didn't raise my rates it just shows. I later switch company's and it popped up again. after explaining what happen they didn't do anything to me also. All I'm saying is insurance company's suck and its not always a best thing to just run to it first. Its like windshield repairs. ya you have it on there but again people are willing to take a hit just to fix a chip instead of paying the $60 because the place is tell you its free.
    Malvolio, skeletron and TacomaUSA like this.
  7. Mar 29, 2022 at 1:17 PM
    #47
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    Just looked at my 2022 and the camera wiring has a connection at the junction point of the main harness.
    musicisevil likes this.
  8. Mar 29, 2022 at 1:29 PM
    #48
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    Looks like rodents
  9. Mar 29, 2022 at 2:58 PM
    #49
    TacoWorldDan
    TacoWorldDan Well-Known Member
    2020 Toyota Tacoma SR5 DC V6 A/T
    If you’re not willing too or don’t have the ability to do any type of electrical wire repair work I’ve always found the best places to bring stuff is audio and radio installation shops. They’ve done a decent amount of wiring for me that nothing to do with radios like switches and lights. Always great quality and better prices.
  10. Mar 29, 2022 at 5:09 PM
    #50
    88seriesiii
    88seriesiii Well-Known Member
    2007 Access Cab 4x4 TRD Off Road 6cyl MT
    OEM with ARE CAP
    reading this made me think of this... https://youtu.be/dA3NvgM0jAQ look at 09:41 for inspiration. You can fix it ! or find a knowledgeable friend who can or at least assist. .
    GrizzledBastard and musicisevil like this.
  11. Mar 29, 2022 at 5:20 PM
    #51
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Next post. Had audio shop fix my harness, 3 months later fuses blow and nothing works. Shit I should have had the insurance replace the harness but now they won’t pay cause the repair was half assed. :annoyed::annoyed::annoyed:
  12. Mar 29, 2022 at 10:36 PM
    #52
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    He can just disconnect the battery and chew the loom and then file the claim at that point. I’m no ethicist, but I could sleep at night with that. The Right To Repair is real, OP. Learning to fix it yourself (perhaps with a buddy who has experience) might be super satisfying….
  13. Mar 30, 2022 at 9:31 AM
    #53
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    if you could peel back the housing at the T where a red wire is visible and expose exactly what wires are cut. if just a red/black/white then simple fix.
    also the housing in the upper right i assume it is going to the tail gate?
