Tailgate strength -2002 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by prizm7dv1, Feb 14, 2012.
  1. Feb 14, 2012 at 5:51 AM
    prizm7dv1
    prizm7dv1 [OP] Member
    Doug
    Plant City
    02 PreRunner SR5
    How strong is the tailgate on a 2002 Tacoma SR5? I just got the truck. I haul hay rolls for my horses that weigh up to 800#. Is it ok to roll the hay off the back without damaging the tailgate? Thanks
  2. Feb 14, 2012 at 5:53 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    No, your tail gate will not last long, if your going to haul big bales, I would suggest you take the tail gate off.
  3. Feb 14, 2012 at 6:43 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    You may be able to increase the weight limit by laying some plywood on the bed,exending it to the gate but then there's the question of the cable supports.
  4. Feb 14, 2012 at 7:41 AM
    scotrinaf
    scotrinaf Well-Known Member
    Scott
    Blountville, TN
    04 PreRunner TRD SR5 4x2 2.7L
    Leer 100XQ, Yakima Roof Racks
    Lay some 2x8's in the bed that extend the length of the tailgate (but not beyond), that should hold quite a bit... Just be careful when rolling them off that you have something in the bed holding them down... Bolt them to the frame close to the cab...
  5. Feb 14, 2012 at 7:45 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I think I read in the manual that the tail gate has been tested to support at least 200lbs. Like everyone said above, use some plywood and 2 x 4s to distribute the weight evenly or just take the tail gate off. The tailgate can be removed in less than a minute.
  6. Mar 6, 2012 at 9:22 AM
    rocco1019
    rocco1019 New Member
    huntington ny
    2011 trd tacoma 17 in rims
    etang cover blue tooth parot
    do u think i need to take my tail gate of if i was to put a gun safe in the pick up th safe is 750 lb
