tailgate stuck???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ripsaw, Feb 21, 2012.
  1. Feb 21, 2012 at 7:34 PM
    ripsaw
    ripsaw [OP] Member
    new york
    07 trd sport
    went to open my tailgate, only one side will unlatch? ever happen to anyone else?if so how did you get it open? it's on 2007 taco.
    thanks
  2. Feb 21, 2012 at 7:35 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    You will have to remove the panel on the inside of the Tail gate. One of the rods probably popped off.
  3. Feb 21, 2012 at 7:35 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    do you have an aftermarket handle like a pop and lock installed?
  4. Feb 21, 2012 at 7:59 PM
    ripsaw
    ripsaw [OP] Member
    new york
    07 trd sport
    rods are not poped off and i don't have a aftermarket handle,does the inside panel come off with the tailgate shut?
  5. Feb 21, 2012 at 8:02 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Yes, take off the screws holding the panel off and have a look
  6. Feb 21, 2012 at 8:02 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2015 DCSB OR Auto Silver Sky 4x4
    I had the pass. side lock go bad.
    Yup. Take off the inside panel with a torx and you can pop it open. If I recall the mechanism was pretty cheap at the dealer.
  7. Feb 21, 2012 at 8:11 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    How do you know without taking off the panel?
  8. Feb 21, 2012 at 8:24 PM
    surfrat
    LI, NY
    take off the top plastic panel. then you will see a hole straight down the center. use a screw driver to push down the plate connecting the 2 rods.. open sesame.
