Tailgate table idea???
Discussion in 'Off-Roading & Trails' started by midwesttaco314, Oct 18, 2019.
  1. Mar 24, 2022 at 9:40 PM
    #61
    4-Day-Work-Week
    4-Day-Work-Week Well-Known Member
    2022 OR DCLB Army Green
    I’ve been working up the same rifle case kitchen idea! I was planning on removing half the foam in the case (right side) and storing dry food there. Jetboil genesis and flash, utensils, and MSR cook set will be set in the foam on the left. I have an Adventure Trail Gear Rugged Tailgate bag to hold fuel, trash bags, cleaning supplies, etc. I’d like to store a big cutting board inside the lid with magnets so I can mount it at camp to the outside of lid of the case after flipping the magnets.
    I was thinking of mounting the case by installing 2 adjustable pieces of webbing with bolts into the case underneath the case to strap around the tailgate while it’s down and allow it to cantilever out. In transit I would strap it to my bed rack.
    I use my truck for work and need to be able to easily move my shit in and out. I think it’s a dope idea, cost effective, and saves a fuck ton of weight versus a slide out. And, most importantly, the truck still gets to be a truck when I want it to be a truck.
  2. Apr 27, 2022 at 7:09 AM
    #62
    galaxyz
    galaxyz Well-Known Member
    2016 Tacoma TRD Off Road
    Following! this is a super interesting idea.
  3. Apr 27, 2022 at 7:29 AM
    #63
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    Someone let me be their test mule.
    Also about to make my own tire carrier with drop down table to make use of space and free up tailgate space
  4. Apr 27, 2022 at 7:36 AM
    #64
    jabba_the_sloot
    jabba_the_sloot Well-Known Member
    full send - very curious
    codyjphoto likes this.
  5. Apr 27, 2022 at 7:47 AM
    #65
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I toyed with this same idea for years. I came to the conclusion that someone could make a killing off of a design idea I had, but I eventually just ended up with a cheap fold out table and am just as happy. Anyways, I think the easiest and most easily marketable idea would be something very similar to the flat metal tailgate panel replacements. Basically take two of those, install the 1st normally, attach a hinge far passenger side, and add a 2nd panel that would still lay flat on top of the other when not "open". When it opens, it would just hinge open like an open book towards the passenger side of the vehicle, basically like a double width tailgate. Obviously would need a slit in it to clear the tailgate support cable, and some adjustable legs for support, but it seems like a really easy idea that anyone with basic fab skills could do.
  6. Apr 27, 2022 at 8:54 AM
    #66
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    That's a cool idea. I might want it to rotate out 90 degrees so the cable wouldn't be an issue. You would lose a bit of space, but the L shape "counter" would be handy too.
    Off Topic Guy[QUOTED] likes this.
  7. Apr 27, 2022 at 8:58 AM
    #67
    Off Topic Guy
    I liked that idea too; I ultimately didn't like that the swivel idea only gave a small amount of added space, since a large portion of it would still be on the tailgate.
  8. Apr 27, 2022 at 9:07 AM
    #68
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    I think it depends on where it would swivel from. If the bottom right corner, for example, there wouldn't be much overlap, but there would need to be some support. Also, I just installed the Snailarmor tailgate panel and while it's cool and would make a nice swing out, it would need some added support if it's going to hold much weight. I think something similar but with a small I beam welded on the bottom with a drop down leg would be perfect, but it wouldn't really be able to lay flat against the bed when stored. The flip out would be better in that case.
  9. Apr 27, 2022 at 9:11 AM
    #69
    Off Topic Guy
    I imagine some sort of steel or aluminum panel would be optimal for either of the ideas, hinge over or swivel design. Another reason I liked the hinge over idea more was because the panel would need to be much smaller, or at least notched in certain spots, in order for it to swivel out and not bind on either side.
    Clarification if anyone doesn't understand the idea I'm trying to explain; look at the design of many of the "tailgate ladders" that hinge over to the side of the tailgate. Take that design, but replace it with a full length tailgate piece of sheet metal, and add some removable legs for support.
  10. Apr 27, 2022 at 9:38 AM
    #70
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Or attach sheet metal and legs to the tailgate ladder...?
  11. Apr 27, 2022 at 9:48 AM
    #71
    Off Topic Guy
    Exactly. But bonus points if you take the ladder out of the equation and just use the same idea for a cheap DIY hinging mount for less money/less bulk. But exactly what I mean.
  12. Apr 27, 2022 at 9:51 AM
    #72
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    The ladder would give you the support under the table as well as the attachment. But it does seem the less sophisticated approach. Now to get someone to fab this up and start selling them.
  13. Apr 27, 2022 at 9:56 AM
    #73
    Off Topic Guy
    I agree; BUT, make the table and supporting legs easily removable and the ladder company would get to sell them as "add ons" with their ladders. But they probably understand theres zero market for it. And is the reason we have these great ideas, yet grab the lifetime plastic folding table for $20 every time we need a table at camp lol.
    dirtnsmores likes this.
  14. May 22, 2022 at 7:39 AM
    #74
    Barcelona21Taco
    Barcelona21Taco Well-Known Member
    21 OR
  15. May 22, 2022 at 8:23 AM
    #75
    codyjphoto
    Cody
    2015 gx460
    A bunch of junk
    Eventually I'll get around to making a function option
  16. Jun 12, 2022 at 1:56 PM
    #76
    Echodawg
    Echodawg Well-Known Member
    Fremont, CA
    2014 TRD OR DCSB
    Stuff and Things!
    I've been toying with this table idea as well. I did not care for my swingout but since getting rid of it I sure miss having that extra table. I was thinking something like this.
    https://youtu.be/nsGNbYqIj7Y
  17. Dec 1, 2022 at 1:42 PM
    #77
    4x4engr
    4x4engr Well-Known Member
    Pete
    2017 Quicksand TRDOR 4x4
    Saw this on FB, pretty sweet.
    scleaf, Coldpunk, jasonvt and 5 others like this.
  18. Sep 25, 2024 at 6:40 PM
    #78
    TyBud850
    TyBud850 Well-Known Member
    Tyler
    Defuniak Springs, Florida (NWFL)
    2012 Black Tacoma DC TRD-OR
    3” lift Icon 2.5 shocks king 650 coils, ALCAN LP W/Sumo springs & FOX 2.0, CBI MOAB 2.0 Front Bumper w/Smittybilt X20 10K winch, CBI Rock Sliders, Mobtown Reinforced Steel Skids & Bed Bars, CBI rear bumper,
    Whats the flat panel you used on your tailgate? Not a fan of the ribs on the stock tailgate.
  19. Sep 25, 2024 at 8:10 PM
    #79
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Think there are multiple companies now that make them, but this is a brand called "mountain hatch" tailgate cover
    TyBud850[QUOTED] likes this.
  20. Sep 26, 2024 at 9:01 PM
    #80
    Coldpunk
    Coldpunk Well-Known Member
    Karl
    Missouri
    2022 Lunar Rock TRD Off Road Long Bed
    TRD lift w/ OME HD rear pack, Diode Dynamics ss3 fogs and 18” light bar, front/rear steel bumpers, Badlands winch, Method 701’s, at4W pizza cutters, RSI Smartcap, RCI sliders, RCI bed stiffeners, Front Runner load bars, Fitcamx, anytime front/rear camera,
    I really like this one. Any more info on it?
