Tailgate theft....How to prevent it....
Discussion in 'Technical Chat' started by chris4x4, Feb 21, 2009.
  1. Oct 7, 2012 at 2:41 PM
    #681
    duque00
    duque00 Well-Known Member
    Long Island, NY
    Does anyone have the problem(s) of the tightening the t-40 bolt with the cables and washers and the having the cable seize and not move?.
    I've tried adding WD-40 to the mix and it doesn't seem to help.
    I've also seen a pic with 2 washers - one small and one big. I have the HD stainless steel washers on now (big ones).
    Any suggestions? Thanking you in advance.
  2. Oct 11, 2012 at 10:31 PM
    #682
    Norville
    Norville Active Member
    Art
    San Francisco Bay Area
    I installed the cable retainer and the clamp mod ... here is a picture of the version of the retainer I put in. Post for the clamp later ... thanks for the ideas.
    Brief write-up of my version on my "build".
  3. Oct 12, 2012 at 6:58 AM
    #683
    Norville
    Art
    Well, there are a few options. Basically, when you add a washer, you have to compensate for the thickness. Otherwise, when you tighten the setup down, the large washer will bottom out on the cable retaining clip and keep it from rotating.
    The solution is just to add a smaller spacer that compensates for the larger washer.
  4. Oct 20, 2012 at 1:41 PM
    #684
    CaptQuinn
    CaptQuinn Well-Known Member
    Quinn
    Alaska to Oregon
    '13 Sprucie Sport
    Dakar EL095R :Front Coils-2885 :Shocks-90000
    Hey all,
    Just a quick shout out thanking TW for being so awesome! I just completed the hose clamp addition to the starboard side of my tailgate. Pretty much the same as everyone else that completed this...
    Somehow I missed the talk about adding washers to the cable retainer, that's next though!
    Cheers!
  5. Nov 11, 2012 at 1:00 PM
    #685
    Big O
    Big O Well-Known Member
    Owen
    Dallas , Texas
    ' 06 X Runner ( Red )
    K & N Air Filter , Magnaflow Muffler , Full Synthetic Oil R/P ,block,trans & differencial , New LED taillights, TRD Short Shifter, a Boulekos Sprint Booster !
    First, when you put the bolt on put a little Locktight (red) on the threads & don't snug it down all the way so the cable moves freely.
    & don't ever use WD 40 for anything as a lubricant.
    It is a dry powder which after the salvent evaporates leaves the area worst/stuck than when you began.
  6. Nov 23, 2012 at 6:11 AM
    #686
    Jackass
    Jackass Well-Known Member
    Jack
    Memphis, TN
    2013 Super White DC 4x4 TRD OR
  7. Nov 29, 2012 at 11:14 AM
    #687
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Does anyone know where in Canada I can buy these. I went to Lowes and Home Depot and they didn't think there was a such thing. Any help would be great.
  8. Nov 29, 2012 at 12:31 PM
    #688
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    Only use red Loctite if you NEVER want it to come off without taking a torch to it. Blue Loctite will do the job just fine and you can remove it.
  9. Dec 1, 2012 at 8:08 AM
    #689
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    I already did the hose clamp. Now I got to get the washers for the cable. So many great ideas here :)
  10. Dec 1, 2012 at 9:32 AM
    #690
    HeavyDuty
    HeavyDuty Member
    Frank
    Planet Earth
    TRD Offroad PreRunner DCSB
    6112 setting 3/2, WeatherTech Floor Mats, ARE Cap
    You know...this option might actually work. Color match might be tricky though.:D
  11. Dec 14, 2012 at 12:55 AM
    #691
    tacoma crazy
    tacoma crazy Member
    Troy
    Conroe,Tx
    2011 Tacoma loaded
    Simple, A simple hose clamp! put it around the poll, and install to where a simple steal makes it imposible!
  12. Dec 20, 2012 at 7:42 PM
    #692
    TACO1267
    TACO1267 Active Member
    Paul
    Manhattan Beach
    2013 Tacoma 4x4 DCSB
    I did the hose clamp. Great tip!
  13. Jan 4, 2013 at 6:14 PM
    #693
    cdb52
    cdb52 New Member
    Doug
    Ottawa
    Tacoma SR5
    Hi.
    It appears that the mpg for a Tacoma varies pretty wildly. I am assuming that most vehicles are automatic transmission.
    May I ask what octane level gas most people are using?
    Doug
  14. Jan 10, 2013 at 8:49 PM
    #694
    Pete4757
    Pete4757 Well-Known Member
    Chet
    GA
    2017 4x4 DCSBOR; 2016 4Runner; 2013 4x4 DCSB SPORT
    Tint, Door Sills, OEM bike rack, LED's: Dome, map, and Lic Plate
    Hey Doug,
    I am getting about 19.5 on 87 Octane. Everything on my truck is still stock. *NB This is mixed driving in the worse place to drive in the entire country....Hawaii-Honolulu!
  15. Jan 11, 2013 at 2:11 AM
    #695
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    Rattlesnake paint job would be awesome! :dancingbacon:
  16. Jan 16, 2013 at 1:51 PM
    #696
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    Obviously a joke.
    You are asking for someone to just break your window and steal your AR (or airsoft, not sure what you have there).
  17. Jan 16, 2013 at 2:10 PM
    #697
    Agro
    San Diego
    I read this thread and here is what I gathered for options
    1. Hose clamp. Easy to install, prevent a thief with no tools from taking.
    2. Gatekeeper. Easy to install, takes a few more tools to remove, but prevent quick thieves.
    Not sure where is best online, but googled this real fast
    http://www.trucknvans.com/Gate-Keeper-Tailgate-Protection-p/200810.htm
    3. Masterlock. Requires a key. Says "Note: Does not fit Toyota Tacoma" but yet you guys show pics. Does it fit? Does it work well?
    http://www.masterlock.com/products/...&modelNumber=MLCOM_PRODUCT_8253DAT&showquiz=0
    I am okay with implementing ALL of these if that is the approach. I dont think #2 can work with #3 installed, and likewise, but perhaps #1 and #3 or #1 and #2?
    Help?
  18. Jan 26, 2013 at 3:56 PM
    #698
    shutuphippie
    shutuphippie Member
    Portland,OR
    New Toy
    3" toytec ultimate suspension lift
    Nice! My Tacoma is too big to fit in my garage now, LOL. I am definitely investing a couple $ and doing this.
    Nice right up.
  19. Jan 27, 2013 at 9:25 AM
    #699
    Agro
    San Diego
    Yesterday I installed the electronic Pop n Lock. This thing is awesome
  20. Feb 2, 2013 at 12:20 PM
    #700
    tacovirgin
    tacovirgin Member
    2013 4-cyl Tacoma Acess Cab
    Four year old thread, but mod still works great on the 2013 model. I found the clamps at ACE Hardware under the brand name "Tridon," though the clamps themselves had "IDEAL" inscribed on them. Two #20 clamps for $4.49. Remove the key once before installing, then you won't need pliers when you remove it the second time. The bolt is nothing but a square peg, so I feel anyone with pliers could defeat it, but hey, it's better than nothing.
