Tailgate theft....How to prevent it....
Discussion in 'Technical Chat' started by chris4x4, Feb 21, 2009.
  1. Sep 9, 2015 at 12:37 AM
    #941
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    +1
    Super easy to do.
  2. Sep 10, 2015 at 7:05 AM
    #942
    djd1
    djd1 Well-Known Member
    Dave
    Winston-Salem, NC
    15 DCLB 4x4
    Great idea - never thought about someone stealing the tailgate itself, but I'm sure it happens all the time. I got 2 SAE #20 clamps at Lowe's in the plumbing section. $2 and 2 minutes is well worth it.
  3. Sep 10, 2015 at 12:34 PM
    #943
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    Those looking for the "key" type of hose clamp the OP used in the video, I found them at Autozone. I'd searched the the big box stores and had no luck. Stashed the key in the glove box so it's handy if I need it.
  4. Sep 10, 2015 at 12:37 PM
    #944
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    The key type does not have a slot for a flat or philips screwdriver.
  5. Sep 10, 2015 at 12:37 PM
    #945
    docloco
    docloco Well-Known Member
    Ron
    Florida
    2015 MGM DCSB 4x4 TRD OR
    Additionally, place your clamp backwards and install using a wrench or pliers and it makes it that much more difficult to remove.
    Boerseun likes this.
  6. Sep 10, 2015 at 1:21 PM
    #946
    DrCherryCoke
    DrCherryCoke Member
    2015 Tacoma Double Cab 4x4 TRD Sport
    Damn! I wish I would have known that earlier. I ordered it from Amazon and I'm watching my truck like a hawk till it gets here.
  7. Sep 21, 2015 at 10:08 PM
    #947
    Firestud5
    Firestud5 Well-Known Member
    San Diego, California
    2025 Toyota Tacoma TRD Sport 4x4
    I just installed one today. Got it from Autozone. Thank you for the idea.
  8. Oct 1, 2015 at 6:31 PM
    #948
    Cicero
    Cicero Member
    Just got done adding the clamp from Autozone as well. Thanks!
    docloco likes this.
  9. Oct 6, 2015 at 7:58 AM
    #949
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    Good Idea. I just bought a hose clamp for $1 dollar from home depot and then grind off the screwdriver head to make it harder for
    thief's to remove. I normally don't go around removing my tailgate anyhow and if I need to remove i'll just cut it off at my convenience. I also put a larger diameter washer around the support cable and lock-tite on the bolt to make it difficult for somebody to unhook.
    docloco[QUOTED] likes this.
  10. Oct 6, 2015 at 11:48 AM
    #950
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Might want to point the screw head where it is inaccessible when gate is closed. Where yours is will be pointed towards ground when tailgate is shut and if you get under truck you can unscrew it from there. I suggest flipping it in same spot where when tailgate is shut, the screw head is pointed up and inaccessible.
    ZKH and bridaw like this.
  11. Oct 6, 2015 at 11:52 AM
    #951
    docloco
    Ron
    Florida
    Well then is 6 on one and half a dozen on the other cause then you can unscrew when you open it.
  12. Oct 6, 2015 at 2:28 PM
    #952
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    Not when you have a pop n lock tailgate lock. :) I have a pop n lock and a locking bed cover. When I installed the hose clamp years ago I did exactly what
    T@co_Pr3runn3r has suggested.
  13. Oct 6, 2015 at 6:29 PM
    #953
    docloco
    Ron
    Florida
    I dont have a pop n lock. Maybe in the future.
  14. Oct 7, 2015 at 4:59 AM
    #954
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I also have popnlock, with stainless gatekeeper piece that fit over the clamp and the cable washer mod..........and now a hard tonneau cover.
    If the tailgate can be opened then not much you can do to make clamp secure other than a tack weld I suppose or maybe a dab of epoxy or jbweld............
    other than use something like this VVVVVVVVVVVVVVVVVVVVVVV
  15. Oct 7, 2015 at 5:30 AM
    #955
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
  16. Oct 11, 2015 at 1:02 PM
    #956
    Quakes15
    Quakes15 Well-Known Member
    Peninsula (BAY AREA)
    TRD Sport Toyota Tacoma X DCSB 4WD
    ICON Stage 3/ Stealth 6's/ Nitto Trail Grapplers
    I have one of these and it is very easy to install. The only problem I have with it is that it is a bit loose. Besides that minor complaint, it gets the job done.
  17. Oct 12, 2015 at 10:01 PM
    #957
    TacoDan723
    TacoDan723 Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    I used the hose clamp style because I don't think someone will want to take the necessary time to unscrew it. I also put a layer of electrical tape under the hose clamp to keep it from scratching the paint. I know, I know...it's a bit much but I don't like scratches. :)
  18. Oct 14, 2015 at 9:48 AM
    #958
    Cr47524
    Cr47524 Well-Known Member
    Chase
    Savannah GA
    2015 Tocoma 4WD TRD OR
    Full 3in OME lift, level 8 bully pro wheels, 285/70/17 Bro's, avid front guard, Anti-theft tailgate mod, tailgate reinforcement skin/cap, relocated the 7pin, door sill covers, snug top,blacked out tail pipe, a-pillar ram mount, 35% on the front,and stubby antenna.
    Done! Thanks for the info.
    docloco and Cicero like this.
  19. Oct 14, 2015 at 10:14 AM
    #959
    docloco
    Ron
    Florida
    This only needs to be done on the passenger side though. Unless your picture is reversed, the driver's side doesn't have an opening for the hose clamp to block.
    tacitos likes this.
  20. Oct 14, 2015 at 10:23 AM
    #960
    Cr47524
    Chase
    Savannah GA
    Ha! Thanks Ron. Didn't read any further then install the clamp. I had a few floating around the shop so on they went. 2 is always better then one right!?
