Tailgate Theft in So Cal
Discussion in 'Southern California' started by surf1, Dec 16, 2016.
  1. Mar 29, 2017 at 8:10 PM
    #41
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    In my searches ive found little
    For a 2017 if its locked, its basically secure aside from scumbag steve using a drill and a torx bit to remove the plastic
    I'm thinking of welding a piece over the gap cause Ill never remove the tailgate
  2. Mar 29, 2017 at 11:03 PM
    #42
    AramsTRD
    AramsTRD Well-Known Member
    Aram
    North Hollywood
    2017 Tacoma Silver Sky Off Road 4X4
    6k LED headlights Baja Design Squadron Sport R fog lights CaliRaised Ditch Brackets w/ Baja Designs Squadron Amber Baja Designs Squadron Pro flush mount on Rear Bumper Kings 2.5 with Resi’s Front and Rear Icon Tubular UCA’s with Delta’s OME Dakars Leaf Springs Timbren U-Bolts Flips kit with Timbren Bumpstops Demello Offraod Front Bumper Smittybilt Winch9500lbs W/ Synthetic Rope TRD PRO Skid Plate for the front Pelfrey Mid, Rear and Gas Tank Skids Pelfrey Rear Bumper with Wilco Tire Carrier Welded on SCS F5’s 16x8 -25mm Wheels BFG KO2's 285 75 16 Prinsu Cabrac AllPro Rock sliders Import Equipment Red & Dark Grey Light Decals
  3. Mar 30, 2017 at 12:14 PM
    #43
    Milc
    Milc Hella Fun
    Orange County, CA
    2016 White DCSB TRD Off Road 4x4
    Only takes a thief one failed attempt to know to bring a screwdriver/sockets for those hose clamps. Guess it's better than nothing though.
  4. Mar 30, 2017 at 8:43 PM
    #44
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    You hunt gold for a living, nuggets laying on the surface all over the place. You can tell that there is a nugget two feet under the ground. Are you going to bring a shovel next time to dig up the ones that are a couple feet under the ground? Nope, you are just going to pick up the ones on the surface.
    xenophon and Garrett75x like this.
  5. Mar 30, 2017 at 8:53 PM
    #45
    Garrett75x
    Torrance
    This
    Mine is figured in such a way that the head of the clamp isint top dead center
    Not like I just put it on there for easy on and off access with a flathead :thumbsup:
