Tailgate Theft Protection for 1st Gen Tacomas
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco.onthefly, Apr 19, 2021.
  1. Apr 19, 2021 at 11:01 PM
    taco.onthefly
    taco.onthefly [OP] Member
    2004 Tacoma Xtracab
    Hey all,
    I was reading through the tailgate lock thread for the second generation Tacomas and wanted to do it to my 2004. Unfortunately, they aren't quite the same tailgate. Is anyone out there using some sort of anti-theft device/setup on the tailgate of their first gen? I usually have a truck shell over the top that latches and locks, but it isn't very sturdy. Any advice or information would be appreciated.
    Thanks,
  2. Apr 19, 2021 at 11:03 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I don’t think you need it, takes a bit more time to get off than a second gen.
    But that’s my opinion.
    ElTaquitoJr likes this.
  3. Apr 19, 2021 at 11:11 PM
    taco.onthefly
    2004 Tacoma Xtracab
    That's good to hear. Just wondering if anyone has some quick and easy projects for some additional insurance. Thanks for the response!
  4. Apr 19, 2021 at 11:16 PM
    97tacotruck
    97tacotruck 1st Gen, Best Gen
    Josh
    Socal
    ‘97 v6 4x4 m/t SC’d
    289k+ Miles 1st gen TRD supercharger w/ 2.2 pulley Snow Performance Stage 2 water/methanol Method NV 305 Bronze 16x8" Falken Wildpeak AT3 OME Nitrochargers w/883 coils Atlas Spring Leafs +3/4” lift Corbeau Seats Total Chaos UCAs PowerStop Drilled & Slotted Rotors, Pads, Calipers Stainless Brake Lines Projector 5x7 headlights w/Morimoto HIDs All-Pro Baja Front Bumper All-Pro Skid Plate Warn Evo VR 8s Winch Baja Designs Squadron Sport Fog Lights Prinsu XtraCab Rack RotoPax Bed Mounted Gas Packs Bushwacker Bed Caps Raptor Liner Bed DeeZee Bed Mat LED Bed Lighting RGB Rock Lights Polk Audio Speakers Alpine Headunit and Amp 8in Subwoofer 00-04 Center Console Needle Bearing Delete ARB compressor (engine bay)
    im almost positive there isnt a latch like 2nd and 3rd gens where you can lift one side and pull the tailgate. pretty much all new trucks are like that, you can just use a hose clamp. but my first gen its bolted on both sides, unless dudes are carrying around socket wrenches
  5. Apr 20, 2021 at 2:14 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    1st Gen tailgates are a lot more difficult to remove. There’s hex bolts and other fasteners like the straps that need to be removed. Definitely not a 30 second robbery like it is on the newer gens.
  6. Apr 20, 2021 at 4:41 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Maybe one of these would help?
    https://www.ebay.com/itm/Tailoc-Tai...04-V6-V8-4x4-2wd-Tail-Gate-Truck/254257528777
  7. Apr 20, 2021 at 7:45 PM
    tone1957
    tone1957 Member
    Tony
    Whittier, CA
    2004 Silver Tacoma 4WD TRD
    Snug Top shell, spray on bed liner.
    I bought a pre-fabd cable from Home Depot (loops assembled). I took off the rear access panel and looped the cable through the tailgate holes and bed holes and around the body frame. The loops ended beneath the access panel and I put a lock on the loops. Bolted the access panel back up. The only issue is protecting the holes from rubbing against the cable when using the tailgate. I put duct tape at the hole and on the cable. Tape the cable before putting inside the holes? I have a locking shell too. Gives me some peace of mind.
  8. Apr 20, 2021 at 10:20 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I use a Pop 'n' Lock and rust :rofl:
  9. Apr 21, 2021 at 5:27 PM
    ElTaquitoJr
    ElTaquitoJr Well-Known Member
    01 Tacoma PreRunner 4 cyl
    That's no exaggeration either. Some poor guy had his tailgate ripped off in seconds at the parking lot of my work. I'd have to watch the video again but certainly less than 30 seconds.
  10. Apr 21, 2021 at 5:50 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    On 1st gens the tailgate is bolted in on both sides. You need a ratchet, socket and extension to loosen them. They don't just pop off with no tools like the newer inferior generations. Yet another 2nd/3rd gen "mod" that's a standard feature on 1st gens, like the gas cap holder in the fuel door, grab handles in the cab and functional mud flaps that actually flap over obstacles instead of breaking.
