Tailgate Weight Capacity
Discussion in 'Technical Chat' started by rwilsond, Mar 24, 2008.
  1. Mar 24, 2008 at 8:25 PM
    rwilsond
    rwilsond [OP] Member
    Orange County, CA
    Owns 2008 V6 Dbl-Cab, Short-Bed PreRunner
    N/A
    Can someone direct me to specs for the maximum weight that a tail-gate can support on a 2008 Tacoma?
    The idea is to have two 350-Lb motorcycles on the bed, with the rear tire of each supported on the rear-most few inches of the tail-gate. But then, it must also simultaneously support the weight of two adults (say 200 Lbs each, assumed worst-case) standing on it while loading & unloading the bikes.
  2. Mar 26, 2008 at 1:47 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    You should cover the whole bed and tailgate with a piece of 5/8" plywood before even attempting that. People have bent the tailgates loading one down the center, and you want to have 2. Not only loading 2, but you want both of them to ride on the tailgate. Better off getting a trailer. Safer, easier, and less chance of shit breaking.
  3. Mar 26, 2008 at 2:30 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
  4. Mar 26, 2008 at 5:38 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Get a trailer, that's just crazy talk about being able to use a pick up truck to haul things, what is this world coming to. :boink: :crazy:
  5. Mar 26, 2008 at 6:39 PM
    piercedtiger
    Jon
    Southern Tier, NY
    :laugh: Tools, furniture, wood, appliances, etc I can see hauling no problem. Hell, even ATVs, lawn mowers, or other things like that. But bikes? Heavy, unstable, 2 wheeled death traps if they slip off the ramp or you fall trying to push it up. Unless you have a long ramp it's usually a steep angle to get the bike up. Do people push or ride them? So many bike ramps I've seen are not solid (sorta like small ladders) so to me it seems it's better to push the bike. If your foot slides, and the thing falls on you it's over. Truck is probably damage, bike is, you are.... So much easier to just get a covered trailer. Easier to load, safe from weather, and locked away from sticky fingers.
    I'd love to get an R1. No way in hell I'm spending $11g's and then risk it falling off a ramp or otherwise getting damaged loading in the back of my truck. A small, cheap dirt bike maybe.
    Not to mention they've damaged numerous tailgates until Toyota redesigned it.
  6. Mar 26, 2008 at 8:37 PM
    rwilsond
    Orange County, CA
    N/A
    I posted the same topic on the ToyotaNation "2005+ Tacoma General" forum
    http://www.toyotanation.com/forum/showthread.php?t=240979
    As of now, it's had over 1000 views, and 34 replies. The replies mostly deal with how to protect the tailgate (Gator Saver, etc). But none of them mentioned anything about the SAFETY of loading & transporting bikes. So, it seemed that I had enough answers to make decisions and move on.
    So, it was quite a surprise to suddenly see replies about the safety aspect (maybe the "Technical Chat" forum is more safety-concious). Having never owned a truck (yet), I wanted to address this issue before learning a lesson the hard way.
    Here in Southern CA, the sight of one or two dirt bikes on the backs of trucks (of all sizes) is common on the weekends, since there are often no legal dirt riding places nearby. Now I'm wondering how many folks end up in the E-Room as a result of the loading & unloading.
    Thanks for the heads-up.
  7. Mar 26, 2008 at 10:12 PM
    utixrunner
    utixrunner I <3 Boost
    Florida
    2007 SWB X-Runner
    TRD S/C, DT Long Tube Headers, Jardine Catback, TRD Intake, Trd Short shifter, TTC Dual Traction Bars, Sway bar bushing kit, c2c lowering kit, lots of other little things
    if your loading dirt bikes back up to a hill to make the loading a little easier
  8. Mar 27, 2008 at 6:06 AM
    piercedtiger
    Jon
    Southern Tier, NY
    I only mention it because I had a ramp slip out from under a riding mower. It have 4 wheels so it just slammed to the ground with me in the seat. Had that been a bike it could have landed on me. Light bikes may not be that big of a deal or kill you, but 350lbs pushing a foot peg into your leg/stomach/chest is going to do some damage.
