Taillamp housings, Hopkins 43355 trailer wiring adapter -- 09
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JKD, Sep 5, 2009.
  1. Sep 5, 2009 at 5:14 PM
    JKD
    JKD [OP] Well-Known Member
    I just installed the Hopkins 43355 trailer wiring adapter in my '09, and there's a couple of pointers for anyone else doing this.
    1. The instructions say you will find the wiring connections "...6 to 12 (inches) underneath the vehicle behind the rear bumper...". You won't find them there. The connections are actually mounted to the taillamp housings, which you will need to remove.
    2. Removing the lamp housings: Open the tailgate and look for three black bolts with 10mm heads. The top one and bottom one are the lamp housing bolts. Remove them. You do not need to remove the center one. The housing will now be loose, but not free. You will need to carefully pull it straight back (don't pull at an angle or rotate the housing) and the two pop-in fasteners will pop free.
    2. Snake your adapter wires up through the holes where the factory wiring goes. Route the wires along the existing harnesses underneath the truck wherever possible.
    3. Apply a little electrical grease to the female connection points and the inside edge of the connector housings for the electrically male connectors.
    4. When reinstalling the lamp housings, you should try to tuck the connectors into the open space as you are installing the housing. Align the push in connectors and push them in until they pop into place. Reinstall the two bolts hand-tight while holding the housing in place.
    Note: The kit was probably designed for trucks where the connections were underneath the truck, with a pigtail leading to the lamp housings. Since the '09 (maybe earlier) has the connections in the housings, there is little to no "extra" wire, so you will need to be careful how you run the wires, especially the passenger side. I considered soldering in an extension on the passenger side, since it is a single wire leading to the adapter, but I made it work as is.
  2. Oct 19, 2009 at 5:35 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Can you tell me how the gray wiring connectors inside the tail lamps come apart? I don't want to break anything by forcing them apart...I have a T connector from Valley Trailer Hitch that goes in between the male and female plugs, but I cannot figure out how to get them apart...dumb, I know...
  3. Oct 19, 2009 at 10:19 PM
    JKD
    Not having it in front of me, I can tell you there's a...tab...of some sort...and you have to lift or depress it and pull the connectors apart.
    Helpful, I know, but really you'd probably be better off examining the T-connector and seeing how the latch is constructed.
  4. Oct 20, 2009 at 9:16 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    I did figure it out. There is a tab that you squeeze, then pull it apart. I got the wiring harness installed, thanks.
