Taillights
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dlead, Jan 19, 2012.
  1. Jan 19, 2012 at 10:22 AM
    Dlead
    Dlead [OP] Well-Known Member
    Daniel
    North carolina
    1998 toyota tacoma ext cab
    Bilstein 5100s with old man emu coils and 2 inch body and 33s and cold air intake and throttle body spacer.
    Hey guys I was wondering if you can put the taillights from like an 01 in a 98 without having to change the wiring?
  2. Jan 19, 2012 at 10:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You have to switch a few of the wires around, and get the longer screws from the 01, but its easy to do. Use a multi meter to find what wires need to go where. With the truck on, activate a turn signal, and see which wire gives the 12v signal. then make sure that wire goes to the turn signal bulb socket. Do the same with the brakes, and youre good to go.
  3. Jan 20, 2012 at 12:02 PM
    Dlead
    Daniel
    North carolina
    Thanks man really appreciate it!! And that wont be hard to do at all ill post pics up when im done!
