Take it back to the Dealer from where I got it, or?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RTD, Mar 20, 2023.
  1. Mar 20, 2023 at 3:27 AM
    RTD
    RTD [OP] Well-Known Member
    Taxachusetts
    2021 TRD Off Road DCLB.
    Just paid it off two weeks ago and an engine light comes on!
    As if the truck knows.
    If you ain't making payments, your making repairs as the saying goes.
    Code says:Cylinder 3 Air-Fuel Ratio Imbalance(Port)
    I noticed a slight loss in performance and MPG.
    Should I take back to where I bought the truck or does it matter?
    The Dealer I bought the truck from is 1.5 hours away, and I have four Dealers closer to home.
    Would I get any better treatment from the place I bought the truck?
    Most of the maintenance and simple stuff I prefer to do myself, anything I don't or can't do myself, I have an excellent mechanic do for me.
    I'm not happy with bringing the truck to a dealer for work, but my mechanic is in the weeds and can't take right away and I use the ruck to work out of all day.
    Not sure if this will be covered by the Warranty.
    30k miles and almost 3 years old.
    Thanks
  2. Mar 20, 2023 at 3:43 AM
    burgershot
    burgershot Well-Known Member
    If in warranty, I’d go to a closer dealer. If out of warranty, find a good shop.
    kona25, BlackTRD4Me, usmc2msu and 6 others like this.
  3. Mar 20, 2023 at 3:53 AM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    It should be covered under warranty. You can take it to any dealer. Do a little googling and find out which one has the better service department.
    Canadian Caber, eurowner and Irons like this.
  4. Mar 20, 2023 at 4:23 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    When Toyota Connected Services receives a message that you've paid the last payment, it notifies the trucks CPU to initiate problems.
    (LOL)
  5. Mar 20, 2023 at 4:32 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    You said the vehicle has 30K miles and is less than 3 years old, so this should be covered by your warranty unless there is a potential cause you have not disclosed. And unless you have a reason not to take it to the closest dealer to you, then run it on over there!
  6. Mar 20, 2023 at 4:38 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Take it to the dealer of your choice and get it fixed under warranty.
    Phlogiston and shakerhood like this.
  7. Mar 20, 2023 at 4:55 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Enough said. Take to a dealer close by. Google for any red flags. When you do work on your truck do you populate the Toyota application? It’s always nice to document
    btiptacoma and Phlogiston like this.
  8. Mar 20, 2023 at 5:30 AM
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    Might this be under the powertrain warranty as well?
    Phlogiston likes this.
  9. Mar 20, 2023 at 5:50 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
  10. Mar 20, 2023 at 6:17 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I think this is the code that usually shows up for the burnt exhaust valve(s). Hope I'm wrong though...
  11. Mar 20, 2023 at 7:01 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    You are most likely right. But it is the exhaust valve not sealing, not a burnt valve. I have done 10 of these head jobs.
  12. Mar 20, 2023 at 7:09 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Outstanding that you paid it off, congrats on that part.
    Based on age & miles given, there should be no reason this issue would not be covered under warranty. Definitely take it back to the dealer to correct. Hopefully not a major issue- Good luck
  13. Mar 20, 2023 at 8:27 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Keep us all informed on the what/why - inquiring minds want to know.
  14. Mar 20, 2023 at 8:33 AM
    BillyE
    BillyE Well-Known Member
    What exactly is the code # (for sake of future searches)
  15. Mar 20, 2023 at 8:41 AM
    RX1cobra
    19 OR
    In your opinion what is causing this? Is it the valve seat or the valve itself? Never really seen an explanation.
  16. Mar 20, 2023 at 8:53 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Wouldn’t this fall under the powertrain warranty?
    rolled93slc and Phlogiston like this.
  17. Mar 20, 2023 at 11:06 AM
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    You should go to the dealer that has the best reputation for their service department. My experience with that code is that the right head will be replaced, which involves pulling the engine. My '18 did the same thing at 32,000 miles two years ago. Took a couple of weeks for the repair, but was fully covered.
    Canadian Caber and rolled93slc like this.
  18. Mar 20, 2023 at 11:26 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    part out
    r2pinter and Beerpayzdabillz like this.
  19. Mar 21, 2023 at 4:50 AM
    rolled93slc
    Jerry
    Lynchburg VA
    I have not been able to figure out what it is. I know that the exhaust valve isn't sealing. I don't know if the seat is deforming, or the valve is. But the valves isn't bent. I've fluid tested the seal on every one that I have done. And it always leaks between the exhaust valve and seat.
  20. Mar 21, 2023 at 5:32 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    If it’s still under 3yr/36mi warranty I’d take it to the dealer quick.
    Don’t delay!!!
