Take-Off's and TPMS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Commocean, Jul 14, 2017.
  1. Jul 14, 2017 at 9:06 AM
    Commocean
    Commocean [OP] Well-Known Member
    St. Petersburg, FL
    2023 Tacoma SR5 DCSB 2.7L Ice Cap
    I'm on the prowl for take-off's, and believe I've read every thread relating to Gen. 3 TPMS. All of the threads I've come across either relate to replacing the TPMS modules with new one's (expensive), switching them 180* from steel wheels to alloy (mixed success), or building "TPMS tubes" to fake out the system. I've also read about nightmares with the system not accepting new modules.
    What I haven't come across is a thread regarding buying take-off's WITH the TPMS sensors in them. For example, if I remove my steel wheels, and install a set of factory, alloy OEM take-off's WITH the sensors left in them, I assume they'll either work, or can be programmed to work? I would only consider going with the same year (2017) take-off's.
  2. Jul 14, 2017 at 9:12 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Yup, you can buy a programming device to do it yourself or go to a tire shop and have them reprogram them. I bought one off Amazon for around $100.
    shakerhood and boynoyce like this.
  3. Jul 14, 2017 at 9:14 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Been looking for this! Spec please- thanks.
    shakerhood likes this.
  4. Jul 14, 2017 at 9:21 AM
    Captqc
    Tigard, OR
    I got a ATEQ Quickset, paid $99 on sale best price I see now is $119. Pretty easy to use once you get the sequence down.
  5. Jul 14, 2017 at 10:11 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    The Quickset tool will work to program the sensor ID numbers of your new sensors into the truck's ECU BUT you need the ID numbers to use it. A separate trigger tool that you point at the valve stem will read and display the sensor ID's and also check that they are working (and wake them up if they are new). Any tire shop should have a trigger tool if you don't want to buy your own.
  6. Jul 14, 2017 at 10:29 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
  7. Jul 14, 2017 at 10:33 AM
    TejasTaco
    TejasTaco Grab a taco
    How much do 3rd gen TPMS sensors cost?
  8. Jul 14, 2017 at 10:42 AM
    RichVT
    Rich
    Northern Vermont
    The ATEQ VT31 is a trigger tool. It will not program the ID numbers into your truck's ECU.
    New TPMS sensors are about $62 each. Tire Rack sells them as well as the online Toyota OEM parts sites.
  9. Jul 14, 2017 at 11:16 AM
    Captqc
    Tigard, OR
    Correct, I should have mentioned that you need the sensor numbers.
  10. Jul 14, 2017 at 11:17 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Been wanting a tool like that too as I have heard of guys having issues after rotating tires while other guys have no problem, knowing my luck I will have issues, lol.
    boynoyce[QUOTED] likes this.
  11. Jul 14, 2017 at 12:06 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    I have a few more months before I will need this, so I am going to continue to research and monitor TW.
    My last free service at the dealership, I will ask for the TPMS codes.
    Figure the tool will pay for itself over the next many years of tire rotations and possible seasonal switch outs.
    shakerhood[QUOTED] likes this.
  12. Jul 14, 2017 at 2:33 PM
    shakerhood
    Southern Ohio
    Im coming up on my first tire rotation and am planning to do it myself, doing same as you in watching on here to see of anyone with a successful tool.
