Take-shudder and rattle fixed!
Discussion in 'Performance and Tuning' started by Amo-cat3, Mar 12, 2009.
  1. Mar 12, 2009 at 8:46 PM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Just put the OME carrier bearing drop kit on an hour ago and cured my take-off shudder. What an easy fix and it makes the truck feel solid and sturdy again. I also lost the vibes I got when going 45+ on the highway. I'm one of the lucky ones with an easy fix.
    I also had this wierd rattle when going about 8-10 mph, sounded like it was coming from the passenger side floor or door. when I was under the truck putting in the bearing drop I flicked the heat shield above the exhaust pipe that goes into the muffler and noticed a rattle. I put rubber washers between the shield and floor pan and between the nut and shield and no more rattle. Just another quick fix and my ride is rollling smooth.
    Aloha from Maui.
    (I meant Take-off shudder in the title.....)
  2. Mar 12, 2009 at 8:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Good to hear! :)
