Take the refund?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whitepony04, May 7, 2020.
  1. May 8, 2020 at 9:58 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Other than for 3rd gen 2019 the low beams are rated poor in testing and I concur, upgraded the bulbs and it helps.
  2. May 8, 2020 at 9:58 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    As in light output. Stick in a plug and play LED or better yet an HID bulb and you'll be amazed at the difference. Toyota uses a halogen bulb because its reliable and extremely cheap compared to LED and HID.
  3. May 8, 2020 at 10:05 AM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I'm not stating that LEDs are not better just that the OEMs are not terrible. Guess it depends on how anal you are in regard to your headlights. I find the OEMs find for my purposes.
  4. May 8, 2020 at 11:59 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    They will do the job but nowhere near as well. I want as much visibility as possible.
  5. May 8, 2020 at 4:20 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
  6. May 8, 2020 at 4:21 PM
    Lt. Dangle
    Ohio
    Seems obvious, doesn't it?
  7. May 8, 2020 at 5:07 PM
    Kevin Jones
    Kevin
    Va
  8. May 8, 2020 at 5:17 PM
    Lt. Dangle
    Ohio
    Yes they are.
    CalcityRenegade likes this.
  9. May 8, 2020 at 7:53 PM
    Huha
    Huha Well-Known Member
    2017 Tacoma trd off road
    Arm rest organizer, dash cam, popnlock, anytime backup cam
    I would've not consider a partial refund. Get your full refund if you do decide to return. I bought my lights from the group buy. There were problems with aiming them and some leds on the drl strip weren't working. I returned them immediately, but too a heck of a long time to get my refund.
    whitepony04[OP] likes this.
  10. May 8, 2020 at 7:57 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    What are those?!
  11. May 8, 2020 at 8:03 PM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
  12. May 9, 2020 at 7:30 AM
    Sandman TRD
    Sandman TRD Well-Known Member
    Indy
    2018 Black DCSB TRD Off Road 4x4
    Recommendation on a plug and play LED or HID bulb? I have been entertaining the idea of replacing with an LED bulb but then I keep reading they actually perform worse in our headlight housings. What are you using?
  13. May 11, 2020 at 2:15 PM
    whitepony04
    whitepony04 [OP] The Big Igloo is coming...
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Eibach pro kit, 3 leaf aal, ecgs, fn fx pros, bfg ko2, gator sfx, Meso stuff
    Is there any type of inline filter or noise reduction shielding available? I'm not stressing over the static, its just a minor annoyance.
