Taken Right Out of My Driveway...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ilove2dubb, Apr 13, 2022.
  1. Apr 13, 2022 at 10:45 AM
    vnix
    vnix Well-Known Member
    2021 white Tacoma DCSB XP Predator
    blind spot mirrors, center tray, bedrug, more to come
    OP, sorry to hear that. Good luck and hopefully it comes back as it left (nothing missing/stripped).
    Think I'd like to see something like what Chevorlet used to use on their berettas back in the 90s. It was a programmable key that you slid into a slot below the dash. Car would run without the key but you couldn't start it without that extra key. That 2nd key with turn offs for fuel pump and starter motor would be ideal, and I think that's what it actually did. Of course losing the key would effectively brick the vehicle until you could get another already programmed key but should be effective. Programming another key was as easy as starting the car then removing the programmed key and inserting a "blank" key. The car would then "program" that key as a valid starting key. Don't think the car would accept or program an already programmed key. Only work around I could see would be the need to handle valet parking.
  2. Apr 13, 2022 at 10:49 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Don't forget this:
    "When I walked out that morning to see my truck missing from my driveway, I immediately pulled up the footage from my 4k cameras. It took them 45 minutes to steal my truck. They began to try and boost my key fob signal which obviously didn't work. They pulled out crowbars and bolt cutters and proceeded to hack at my door for 10 minutes. The thieves entered from the rear door to not trigger the alarm, and proceeded to re program the key. I did not know that the rear doors were not connected to the alarm which is ridiculous. I am infuriated thinking that these assholes were 20ft from my daughters window especially for that period of time."
    If thieves want something, they'll do everything they can to get it. The fact that they went this route means you were specifically targeted. They tried for 45 minutes. I'm not sure what else Toyota could have done for you in regards to security.
    This sucks, and I hope it never happens to me. Stories like this are why I always park my truck in my garage. I also set the alarm even though it's in the garage. Because, hey...you never know!
  3. Apr 13, 2022 at 10:50 AM
    arthur106
    arthur106 Well-Known Member
    Jacob
    Houston
    Black '10 SR5 4WD 5MT
    These people have no place in society. I'm disappointed with our sissy governments that have been going too easy on crime for far too long.
    jetfishn, Tacomod, Vmax540 and 8 others like this.
  4. Apr 13, 2022 at 10:50 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Castle doctrine should be universal. Another reason I will stick to my MT with basic key. It could still be stolen but much less likely. Did you have a motion sensor light where they were? If not, it would be a good idea to hopefully spook them in the future.
  5. Apr 13, 2022 at 10:54 AM
    Ilove2dubb
    Ilove2dubb [OP] Well-Known Member
    Jeffrey
    Montreal, Quebec
    2020 Tacoma TRD Sport in Cement
    It's funny that you ask this because I have a flood light that was on them the entire time that they were there. There were two thieves, and while one was programming the key, the other was standing right under the camera lit by the flood light, and looking directly into the camera lens. They obviously knew that I live in a quiet area, and that it would be unlikely for someone to drive by at that time early in the morning. They were both wearing masks so there's no chance of identification.
    It actually took ten minutes for them to break in my truck using manual tools. If it hadn't been for my faraday pouch, they would have been in my car at the press of a button. The issue with Toyota's security is the reprogramming of the key. European obd2's do not allow for a new key to be programmed and the original to be disconnected from its identity. Once they do this, it's as if your truck is a new unit and not even able to connect to "Toyota Connect." You are also incorrect as to how the alarm is triggered. Both of my dome lights were turned on, along with my bed light which they immediately turned off. That in itself would be a major security issue if the alarm would only sound if the lights were illuminated. You are a special human being to insinuate that someone's truck being stolen is, "on them," even if I were to have left my lights off. (Not the case)
    A kill switch is definitely on my list of theft prevention for the next truck. However, it wouldn't be a deterrent for theft as they wouldn't be aware of its existence. I plan on doing this as well on the next one, but the key is to discourage them entirely so that they do not damage your truck.
  6. Apr 13, 2022 at 11:01 AM
    coma toy
    coma toy Off Road Taco
    I'm so paranoid, and do use the Faraday pouch, but apparently it isn't enough. Only safe solution is my garage.
    Junkhead likes this.
  7. Apr 13, 2022 at 11:02 AM
    3r3Taco
    3r3Taco Well-Known Member
    So.Cal
    17 SR5 DCSB
    Factory Stock
    That sucks to hear.
    If they want your truck they will take it. You can have have ecu disable, starter relay disable, fuel pump relay disable. And they will still hook up to the truck and tow it away. If they want it, they will get it.
    Borracho Loco and auskip07 like this.
  8. Apr 13, 2022 at 11:05 AM
    Mikeh80
    Mikeh80 Well-Known Member
    OHIO
    2022 TRD OR DCLB
    Sorry to hear this.
  9. Apr 13, 2022 at 11:08 AM
    hilighter
    hilighter Master of Disaster
    Portland, OR
    21 Tacoma MGM TRD OR DCSB ABCDEFG
    3” Ironman IM2.5 lift Body Armor stubby front bumper 10k Superwinch Ironman Raid rear bumper Custom sliders Nomad 501 17x8.5 Satin black wheels Smartcap Dashmat
    Wow, I guess it might be best for me to start using my ‘Club’. So bummed for you.
    eurowner, PzTank and Junkhead like this.
  10. Apr 13, 2022 at 11:10 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Man that’s sad, wish you luck man.
    Look at those pieces of shit, fuckers. I hate thiefs!
    Taco Blanca, t2c, 44-16 Taco and 3 others like this.
  11. Apr 13, 2022 at 11:10 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Ok it took them 45 minutes to steal your truck. Expecting toyota to make a truck thats thief proof is unreasonable. What triggers the alarm if its not the doors?
    Ill find out tonight and lock myself in my truck (back seat) and see if that triggers a standard alarm.
    Borracho Loco, Skydvrr and Junkhead like this.
  12. Apr 13, 2022 at 11:17 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  13. Apr 13, 2022 at 11:19 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Oh I have DM’s with a guy who specializes in this stuff. He’s next level compared to me. Has friends in the biz.
    I think people mostly steal keys these days, way easier.
    s0ar and Skydvrr like this.
  14. Apr 13, 2022 at 11:20 AM
    Borracho Loco
    DFW, Texas
    I just tried this. I was just as curious as you were and this is what I found out: It doesn't make the alarm go off!
    I hopped in back seat on the drivers side, hit the "lock" button on my remote twice, waited 15 seconds then opened the door (I had to manually move the lock on the door panel to get out). When I did, no beeping alarm!
    I thought, okay, maybe it will if the FRONT door opens. I tried the same setup. I hopped in the drivers seat, pressed the "lock" button twice, waited... Then opened the door. NO SOUND.
    auskip07[QUOTED] likes this.
  15. Apr 13, 2022 at 11:22 AM
    #35
    auskip07
    Skip
    Atlanta, Ga
    very strange
  16. Apr 13, 2022 at 11:24 AM
    #36
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Most of the time there’s a X amount of seconds time out. Did the alarm LED change state?
  17. Apr 13, 2022 at 11:25 AM
    #37
    3r3Taco
    So.Cal
    17 SR5 DCSB
    Factory Stock
    How is that going to stop a tow truck from hooking up and going?
    Repo companys hook up and go really fast, they can then drive else were to secure it.
  18. Apr 13, 2022 at 11:25 AM
    #38
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    My ranger was the same. You could set the factory alarm and easily open any doors from the inside. Dumb dumb dumb.
  19. Apr 13, 2022 at 11:28 AM
    #39
    Borracho Loco
    DFW, Texas
    I think it's safe to say this isn't a "real" security system/alarm. It's a glorified door locker/unlocker!
  20. Apr 13, 2022 at 11:32 AM
    #40
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Years ago if you flaunted your freshly bought new iron in quebec it was an open invitation for getting ripped off. Sounds like this hasn't gotten any better.
