Taking a heat gun to the windshield to defrost it...
Discussion in '1st Gen. Tacomas (1995-2004)' started by coff33, Dec 5, 2021.
  1. Dec 5, 2021 at 7:56 AM
    coff33
    coff33 [OP] Well-Known Member
    5vzfe manual
    what do you think?
  2. Dec 5, 2021 at 7:59 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Might be ok if you keep the heat even.
    But why?
  3. Dec 5, 2021 at 8:02 AM
    coff33
    5vzfe manual
    Something not working with heating. Will have to wait till spring to fix because no indoor parking.
  4. Dec 5, 2021 at 8:05 AM
    0xDEADBEEF
    Ah I see. It doesn’t take much heat and it has to be over a wide area - might consider a hair dryer. My heat gun is too focused for this.
    have you looked at the valve on the middle firewall under the hood? Seems to be a common fail
    Wulf and TWJLee like this.
  5. Dec 5, 2021 at 8:08 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Sounds like a good way to crack the windshield.
    Suggest you invest about $5 for an ice scraper. Learn how to use it. It takes less than 5 minutes to clear the frost.
    BTW, windshield wipers are very poor scrapers.
    If you are talking about the inside of the windshield, then suggest you get the system fixed. Or a 12Vdc fan blowing on the inside can help......some.
    Wulf, SpokeWench, Nevin and 1 other person like this.
  6. Dec 5, 2021 at 8:09 AM
    coff33
    5vzfe manual
    There is a coolant leak from the heater core whenever the heater is on. Only stops when coolant flow thru heater is stopped. I think it's a cracked pipe. Was going to change it out when I do I coolant flush (along with valves).
    0xDEADBEEF[QUOTED] likes this.
  7. Dec 5, 2021 at 8:18 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Sunday thread! Pre NFL early football games. New tradition.
    Bivouac likes this.
  8. Dec 5, 2021 at 8:22 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I used to live in MD it does tend to get a bit nippy in the winter you don't like a warm truck?
  9. Dec 5, 2021 at 10:03 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Just buy windshield cover off Amazon....
    windshield glass is multi layer.....heat is bad news....
    As far as the leak....when u shut off the heat coil flow...it still stays pressurized...
    I would suspect the valve or connections around it...
    SierraMare likes this.
  10. Dec 5, 2021 at 11:17 AM
    Tac0mah0lik
    Tac0mah0lik Member
    I got a can of Prestone windsheild deicer In my Taco when I bought it. I don't think ill ever go back to scraping unless its super thick ice.
    SpokeWench likes this.
  11. Dec 5, 2021 at 12:35 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Most likely it is the inside of the windshield that has the Ice . The outside is easy.
    I drove home from Wyoming in January to Eastern Pa Pretty much needed to have the drivers window rolled down
    I would forsure get that issue fixed.
  12. Dec 5, 2021 at 6:21 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    they sell 12v plug-in defrosters you can mount on your dash for the winter :D
    TACOTU3 likes this.
