taking a road trip with a trailer??
Discussion in 'Towing' started by RDAY, Mar 31, 2011.
  1. Mar 31, 2011 at 5:25 PM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    I am going to ohio to pick up a 1200lb dune buggy. With a 20ft trailer its a 450 mile trip one way. I plan on doing the trip there and back in the same day i do have a hitch and the plug on the back of the truck so the lights and everything will work but will i have a problem going that far without an electronic brake controller?
    Thanks for the help my 1st time taking a trailer ne where
  2. Mar 31, 2011 at 5:37 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Hmm, its not the 440 freeway miles to worry about, nor the predictable red lights.. It could be the surprise stop that you do when a car in front of you stops for a red or such.
    I'm assuming you'll be doing posted speed on the freeway, 75mph?
    I cant bless your trip, or predict how well you drive,but id say its possible , but be ready to follow farther and go slower.Also,what is your states law.
    i'd get the box if you are somewhat unused to towing.The extra stopping distance doesnt seem much , until its downhill and u need a faster stop.
  3. Mar 31, 2011 at 5:56 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    our speed limit is 65 on the highway which i usually do about 77 lol but i will def be going about 65 with the trailer the whole way the dune buggy does have a tow bar on it but i believe i would have to have it on the road with plates in order to just tow the dune buggy which would be easier but idk how to get it legal to
  4. Mar 31, 2011 at 6:07 PM
    ppeter
    ppeter Nerdfighter
    Paul
    Twin Falls Idaho
    08 PreRunner SR5 & 10 DC 4x4 Offroad
    PreRunner: Added fogs, cruise, Trailer hitch, TRD wheels & rugged trail T/A's, window tint. D/C: Duratrac's, Viper Smartstart, window tint.
    A lot of smaller trailers don't even have trailer brakes. It's mostly for big heavy equipment trailers and campers like 10000 lbs and up. Just use your gears (go slow) if you fall off a grade and lots of following distance. It's not a problem.
  5. Mar 31, 2011 at 6:15 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Most states have laws that say you need trailer brakes at 3500lbs and up.
  6. Mar 31, 2011 at 6:17 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you will be fine. tow about 2.5k with my 2.7l and dont have nothin haha. and i tow it with a 97.
  7. Mar 31, 2011 at 6:21 PM
    ppeter
    ppeter Nerdfighter
    Paul
    Twin Falls Idaho
    He said it was a 1200 lb load. Even with a heavy ass trailer he would be way under that.
  8. Mar 31, 2011 at 6:22 PM
    S.B.
    Sean
    San Diego
    15 Taco
    I was talking about your statement that said you only need trailer brakes with 10000lbs or more.
  9. Mar 31, 2011 at 6:23 PM
    ppeter
    ppeter Nerdfighter
    Paul
    Twin Falls Idaho
  10. Mar 31, 2011 at 6:25 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    x2
    i tow a lot, with and without trailer brakes. even with a trailer heavier than the buggy itsself, you'll have plenty of stopping power, just remember you have the trailer behind you and you'll be just fine.
    hae fun with the new toy!
  11. Mar 31, 2011 at 6:27 PM
    bcb97
    bcb97 Well-Known Member
    I wouldn't worry about it. Keep it at the speed limit and you'll be fine. Your stock brakes can handle that load with ease.
  12. Mar 31, 2011 at 6:29 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    I would not go over 55 mph to be safe. You should be fine, just keep an eye out for situations that can lead to trouble. Try to plan the trip when the roads are not busy.
  13. Mar 31, 2011 at 6:30 PM
    Tacoyota
    08 4wd
    So ,perhaps 2200 lb combined trailer and buggy. Its around 1/2 your rigs weight, that has a lot of merit to needing a box.A lot of it isnt just the actual weight , but how that weight compares to the tow vehicle. I think its doable as is with no box, for me though I dont like the surprises.
    PS , I saw NY at 1000lb and up on that link above.
  14. Apr 1, 2011 at 9:30 AM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    I towed a trailer with I think about a 3500lbs gross with no brake controller and it was actually scary. The towing (pulling, handling) was fine but any faster than normal stop was scary.... If you have the factory tow package you can just plug and play the controller if you can beg/borrow one.
    At least do a near panic stop from highway speed somewhere safe and empty and get a feel for just how long it will take. Hook up the trailer and do it with the empty trailer first anyways, then figure on the extra weight making it a lot worse.
  15. Apr 10, 2011 at 6:22 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    You can probably use Overdrive on the way up and Drive on the way back. I would keep it 60-65 mph. Give yourself some extra room. Keep it in the slow lane and you'll be fine.
