taking apart center counsel in 08 auto?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xtirtzt, Jan 26, 2009.
  1. Jan 26, 2009 at 7:10 AM
    xtirtzt
    xtirtzt [OP] Addict.
    Connecticut
    08 trd sport 4x4
    afe pro-dry S, flowmaster 40 series, ipod interface, black headlights, yellow fogs
    i need a bit of "know how", im trying to take apart my center counsel because i would like to route a cable from my glovebox where my ipod interface is to the first little compartment thing in front of the cup holders in my center counsel... im planning on just drilling a little hole in the bottom or the compartment (just enough to get the cable through) and then weaseling a little grommet in there for a "professional installation"... just dont know how to get it apart to get the cable to that point?
  2. Jan 26, 2009 at 10:19 AM
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    Take a look in the audio/video section. Look at either the stickys or you might try my thread on installing a GPS unit, which involved taking apart the same stuff.
  3. Jan 26, 2009 at 10:29 AM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    12 DCSB TRD Off-Rd 4x4, Roof Rack, Tube Steps
    K&N drop-in air-filter, extra D-rings, Custom Console lock-box, Leather heated seats, Studly Driver
    Very easy. I just did this when i built my console lock box. The plastic surrounding the shifter, including the rear single cupholder, just pulls up. You can use a plastic putty knife to keep from scratching the console. It's tight but easily to pull up. Once that's out you need to remove the 2 10mm bolts from inside the console and the 2 phillips-head screws holding the console to the shifter housing. Here is where I messed up. you can't just pull the console out. The front (where the 2 screws were) has to lift up about 1/4 to 1/2inch then slide backward. you'll see when you get it apart that there are plastic hooks that lock into position when you put it back together. It'll take you less then 5 minutes.
    Good luck.
  4. Jan 26, 2009 at 10:34 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    just make sure you unscrew the shifter knob before pulling up. that way you can get it off.
  5. Jan 26, 2009 at 10:55 AM
    cvillechopper
    Charlottesville, VA
    Oh yeh... what he said:D
  6. Jan 26, 2009 at 11:04 AM
    xtirtzt
    Connecticut
    08 trd sport 4x4
    how do i get the drink holders out?
  7. Jan 26, 2009 at 11:27 AM
    Chickenmunga
    Hillsboro, Oregon
    If it's the one in the very front, pull the black divider out, then pull out the tray - get your fingernails under the front lip.
    If it's the rear ones, they are part of the whole silvery section, which includes the portion around the shifter, etc. get your fingernails underneath the lip and pull upwards.
  8. Jan 26, 2009 at 11:29 AM
    Kicker_Of_Elves
    Kicker_Of_Elves If it bleeds we can kill it
    USA
    08 Tacoma Access Cab TRD Off Road
    Front Skid Plate, Exhaust Tip, Tinted Windows: 35% Front Sides, 5% Rear Windows, Devil Horns Emblem, Rear TSB, BLHM, Shorty Antenna, 6000k HID Headlights.
    MAGIC!
    Just kiddin i'm interested in the answer too.
  9. Jan 26, 2009 at 11:39 AM
    Chickenmunga
    Hillsboro, Oregon
    His thing on the left says auto, but the process is still similar at this point.
