Taking apart the TRD Supercharger
Discussion in 'Performance and Tuning' started by Dutch, Feb 22, 2009.
  1. Feb 22, 2009 at 10:29 AM
    Dutch
    Dutch [OP] Well-Known Member
    Wilmington, NC
    07 4x4 Taco
    As much as I hate going back into mods under the hood, I have to pull the main rotor assembly out of the casing of the TRD supercharger. I have the 1GR (or was once). Has anyone here done this before and if so, other than spilling oil during the process, what to expect? As usual, I can't get any help from the sorry tech service at TRD. The snout is damaged from changing pulleys and I am worried about the imbalance. I think I can save the main shaft by turning the OD slightly from the pulley forward and drilling the center hole slightly larger, and tapping to a larger thread. In the process, I am also going to pull the cams that were made for me and try to sell them here. They are fantastic, but void warranty, and I have others waiting to go in.
  2. Feb 27, 2009 at 8:44 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    I have some pictures of one of my 5VZ superchargers taken apart on my webpage.
    www.GadgetOnline.com
    You may want to give me a call about what you are up to. I may have some good pointers and suggestions that may save you a lot of trouble.
    877-8URDUSA x3
    Gadget
  3. Feb 27, 2009 at 12:20 PM
    Dutch
    Wilmington, NC
    07 4x4 Taco
    Thanks Gadget, I was thinking you might find this. I will definitely give you a call. I have damaged the snout of the TRD S/C by changing pulleys and now have the URD pulley I want to install. The OD has mushroomed at the end and the internal threads no longer exist. I have access to a large machine shop, but have never worked on a S/C. I should have put the URD blower in.
  4. Feb 27, 2009 at 12:29 PM
    Gadget@URD
    You should give me a call so I can help you get that sorted out.
    Gadget
