taking emblems off
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, May 28, 2010.
  1. May 28, 2010 at 5:34 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    anyone know an easy way, are they bolted or glued?
  2. May 28, 2010 at 5:36 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  3. May 28, 2010 at 5:37 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    don't think a heat gun is a good choice. it could damage the paint if left in one spot too long. i used hair drier, fishing string and goo gone.
  4. May 28, 2010 at 5:39 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    I just used my finger nail and they pealed right off. Then i used some OOPS to take off the glue. Fishing line works well to.
  5. May 28, 2010 at 5:59 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    ok well i have a trd sticker on there too, use a blow dryer with that too?
  6. May 28, 2010 at 6:23 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Unless your a complete tool a heat gun is safe and is the effective solution for removing badges. Ask any professional tint, pinstripe, or decal installer. You can get a pretty cheap one at Home Depot for about $20 I belive the brand is called Watson. Anyways you just give it a couple swipes with the heat on to heat up the adhesive on the emblem and it will come right off. You can use your finger nail and fishing line, then use 3M adhesive remover, some rubbing compound, and an orbital buffer to get the residue underneath off.
  7. May 28, 2010 at 6:25 PM
    mwild
    Vernon, NJ
    03 2500 Dodge Ram
    You can use a heat gun just be careful. That is the easiest way to get the TRD decale off.
  8. May 28, 2010 at 6:56 PM
    Madjik_Man
    Colorado Front Range
    For badges: park in the direct sun when it's hot out. Get 10# test fishing line and run it between the badge and body. Make sure to clean the area around/on the badge so you don't scratch the paint. Use Goo Gone (or something like it) to remove the residual adhesive. Wash after all adhesive is gone. Then wax
    Sticker decal: Get one of those eraser wheels. They work awesome.
  9. May 28, 2010 at 7:01 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    SEARCH FUNCTION!:D
    Your best friend on TW!:D
  10. May 29, 2010 at 9:03 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    thanks for the help guys, i got all the emblems off, i can see there the emblems used to be because of the paint fading a bit but i think after a clay bar and some wax it will be hardly noticeable
  11. May 29, 2010 at 9:06 PM
    Koov
    Koov Well-Known Member
    Seattle
    2019 DCLB TRDOR
    ^^ Exactly! Sun, fishing line, some goo gone and wax and it will look great.:D
