Taking front grill off for painting/plastidipping.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KDOG, Nov 5, 2013.
  1. Nov 5, 2013 at 3:28 AM
    KDOG
    KDOG [OP] Well-Known Member
    Belleplain, NJ
    Bilsteins, OME 884s, 3 stage progressive AALs.
    Anything I should know beforehand so I don't break it?
  2. Nov 5, 2013 at 4:37 AM
    Kilo Kilo
    Kilo Kilo Active Member
    Kyle
    Central Mass.
    2012 AC SR5 2.7L 5-Spd
    Tonno Pro tri-fold Bed Cover, LED's, Reflective lettering
    There's two screws and 5 or 6 plastic rivets. One of the rivets is on the bottom in the center and might be hard to see from above. Also, it will help to pop out the trim pieces below the headlights.
  3. Nov 5, 2013 at 4:53 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Depends on what year model yours is. 2012 and up are completely different.
  4. Nov 5, 2013 at 5:34 AM
    KDOG
    Belleplain, NJ
    I'm 2011
  5. Nov 5, 2013 at 5:41 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    There are 2 metal screws and 2 plastic rivits on the top of the grille that need to be removed. Use a flat head screw driver to pop the center of the plastic rivots up, then they will pull straight out. After they are removed, pull the grill straight up and out. There are retainer clips that attach the grill to the headlights that keep it in place and you'll hear the clips letting go as you give it a tug (actually sounds like you broke it but it's just the plastic clips releasing.
  6. Nov 5, 2013 at 8:04 AM
    KDOG
    Belleplain, NJ
    OK. Payday Ill head out to find some flat black!
  7. Nov 6, 2013 at 7:50 AM
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    When I put my grill back in after plasti dipping this past weekend I couldn't get the clips that still hold it after you take the screws out and the plastic rivots to snap back in after I finished painting. It was getting dark so I just let it for now and put the plastic rivots back in and the two screws on top back on. How do I get it to snap? I took a small screw driver to help un snap the clips BUT did NOT break them.
