taking long and long to fire up
Discussion in '1st Gen. Tacomas (1995-2004)' started by vantaco, Nov 5, 2010.
  1. Nov 8, 2010 at 4:33 AM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    I could be mistaken, but I believe this is the fuel pressure regulator.
  2. Nov 8, 2010 at 8:57 AM
    vantaco
    vantaco [OP] Well-Known Member
    02 Taco Xtracab TRD Step Side
    ya that was my next step was to pull the plugs etc
    i have an old service report for the truck stating the plugs were changed like 50K kms ago or less i think, but i'll pull them and have a look....pretty sure i've got coil packs...no dist and rotor
    i am getting pretty terrible fuel milage as well (see my fuelly below)
  3. Nov 8, 2010 at 12:58 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Unfortunately I am having the same problem as well on my 2003; and it sucks because since I drive long distances for school and work I don't want to be stranded out in the middle of nowhere. Same symptons.
    .1.) Turn the key, it cranks strong, then it I release the key and it almost dies then fires up. It's very strange. The battery is less than 2 months old. It drives great no hesitiation or strange idle. I have no clue.
  4. Nov 8, 2010 at 4:40 PM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    Coolant Temp sen. tells it how much fuel to give it depending on how cold or hot it is.
  5. Nov 8, 2010 at 5:01 PM
    Yamaha Dave
    ^ I think you're right, it starts fine when it's cold, but once it gets up to normal operating range that's when it becomes a problem.
  6. Nov 9, 2010 at 10:34 PM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    Having this issue as well, though it's intermittent. Happens a few times a week. Battery still tests okay (12.59), installed new spark plugs and wires a couple months ago. Only 45k miles on my '03 and I doubt the fuel filter has ever been changed but the issue only started recently.
