Taking out 1/4" Spacer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MX81, May 23, 2010.
  1. May 23, 2010 at 4:17 PM
    MX81
    MX81 [OP] Well-Known Member
    Dallas
    2014 TRD Offroad PreRunner
    I currently have the Toytec 1/4" spacer along with 5100s at .85. The spacer seemed to over compensate for my lean. My question is if I take the spacer out will I be good without getting it realigned ? Thanks
  2. May 23, 2010 at 4:32 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Whenever you change the suspension or steering, even if just a little, it will change the geometry. Yes, it needs to be re-aligned.
    This is even true for changing the rear suspension. Lifting or lowering the back changes the caster up front.
  3. May 26, 2010 at 6:37 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    While what BirdTRD says is true, I would think for now, you could get by without..
  4. May 26, 2010 at 6:42 AM
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Alignment should still be close. If your tires are new, you may want to get the alignment done, otherwise, I'd wait till you get new tires.
  5. May 26, 2010 at 6:44 AM
    Rich Beauregard
    Rich
    New London, CT
    Are you selling the spacers? If so how much? Thanks, Rich
