Taking out interior scratches
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZonKs, Sep 20, 2007.
  1. Sep 20, 2007 at 7:30 PM
    ZonKs
    ZonKs [OP] Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    I have some scratches on the passenger's side inside door panel (the black part just below the window). Does anyone have any idea how to fix this, or at least lessen their visibility? I really dont want to shell out $480 for a new door panel, and the little girls at COOL IT WINDOW TINT in Upland, CA (NEVER GO TO THIS PLACE!), will not man up and take responsibility for wrecking my interior.
    Any help at all would be appreciated greatly.
    Ted
  2. Sep 20, 2007 at 7:49 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i wouldnt mind finding out either. i have some small ones in mine. i was thinking about one of the vinyl repair kits that you can mix to match ur color...but i dunno how well it'd work
  3. Sep 21, 2007 at 8:03 AM
    hokihigh
    hokihigh Active Member
    Blow dryer on high, or a heat gun on the lowest setting, just heat and rub:)
  4. Sep 22, 2007 at 10:37 AM
    bbarian333
    bbarian333 Well-Known Member
    SoCal
    06, Accesss Cab, TRD Sport
    TRD exh, K&N drop in,TRD seat cvrs,tsb springs
    Wow Zonks, That scares me. Just had my windows tinted. I got lucky , only a few light scratches in the rubber around the back windows. But i now have a few bubbles in a couple windows and im taking it back. I'm going to have to watch them like a hawk to make sure they do no damage.
  5. Sep 23, 2007 at 5:37 AM
    Viper-2
    Viper-2 Secret Agent
    Keith
    Charleston, SC
    Prerunner with many mods
    Really??:confused: (Spoken in a Stan Marsh voice)
  6. Sep 23, 2007 at 10:55 AM
    robj
    robj New Member
    07 double cab 4x4
    There is a company called Chem-Pak they specialize in flaw repair spray for injection molded products. We use it at our work (we do interior products for several oems) and I have used it on a guys Tacoma as well with good results. You will need to lighten the scratches up with a propane torch not anything hotter or it will melt. Use a torch with a push button ignition and lightly pop the scratches out. then go over the plastic with Chem-Pak "A" or "AA" gloss spray for polypropylene. This will give it a even appearance. This will lighten the scratches up considerable and blend them in but will not completely repair them.
    PS be sure to mask anything up that you do not want the spray on and be sure to read the mfg instructions.
  7. Sep 23, 2007 at 11:08 AM
    Mudbug
    Mudbug Well-Known Member
    Amsoil 0w-20 engine oil and Amsoil Full synthetic 75w-90 in the Transmission, transfer case, front and rear Differentials. AFE Cold Air Intake
    What an awesome first post to the forum!
  8. Sep 23, 2007 at 4:55 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    A local audio compant put some scratches on my lower dash while installing a mp3 connection. They have a company that comes out and mixes & matches paint for touch-ups. Which got me thinking...
    Why not just pop out one of your removable interior holders, take it to Home Depot & have them computer match the color. They can test it on the back opf the pop out. Usually only $6 for a QT (the smallest size I think).
  9. Sep 23, 2007 at 6:50 PM
    reid
    reid Well-Known Member
    Vancouver BC Canada
    2007 V6 Access Cab
    Magna Flow stainless cat-back, 3" Toytec Lift, 32" Mickey Thompsons
    the heat gun idea is the right way to do it.
    I removed some small scratches just by rubbing them with the round smooth plastic handle of a screw driver. For the large ones I uses a heat gun on the lowest setting and used the same rubbing idea.
  10. Sep 26, 2007 at 10:18 AM
    danusa
    danusa Well-Known Member
    My wife complained about our belt guns scratching the chairs. I have the friends and the sidearms but not the wife.
  11. Feb 10, 2010 at 4:39 PM
    Airwolf NSX
    Airwolf NSX Well-Known Member
    Irvine, CA
    2010 Tacoma TRD Sport Double Cab
    going to revive an old post... but a PROPANE TORCH!?!?!?! Has anyone else tried this? :confused:
  12. Sep 25, 2010 at 2:49 PM
    twostring
    twostring Active Member
    Sorry to revive an old thread a second time, but I just tried the heat gun method to remove a scratch on my dash (gray interior) and it worked perfectly. I didn't have to rub out the second scratch. As soon as the plastic was warm enough, the plastic kind of folded in to the scratch and it vanished instantly. For the most part, the overall texture of the dash is intact as well. Not like new, but hard to tell the difference.
    Also, be very careful when heating up an area with another panel close by. Although the plastic looks the same (same color and texture), the type of plastic may be different and melt quickly. I ran into this problem with the dash tray just below the ignition.
  13. Sep 25, 2010 at 4:58 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    To remove scratches and what have you I have heated up a clean putty knife with a bernzomatic torch .... got it red hot ... and ever so gently "smoothed" the effective area.
    I tried it several times on an odd piece of similar plastic I had laying around until I got the right "feel" of doing this.
    Try it on an area not out in the open.
    Another way is using a bic lighter and just barely going near the surface.
    These are tried and true methods.
    I am not responsible for any damage to you (3rd degree burns), you Tacoma (holes melted through), or you garage (being burnt down).
  14. Sep 4, 2015 at 1:23 PM
    Bubblehead60
    Bubblehead60 Member
    2015 Tacoma Access Cab TRD Sport
    Gave the heat gun method a try after my dog scratched up the upper door panel area. Seems to work but the area I heated looks a bit faded. Will have to follow with some plastic polish or back-to-black to see if it'll clean up. Otherwise, it may look worse than it did before...
