Taking turns in 4wd
Discussion in 'General Automotive' started by z33tec, Jan 28, 2009.
  1. Jan 28, 2009 at 12:28 PM
    z33tec
    z33tec [OP] Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
    I know you aren't supposed to take tight turns while in 4wd, so what is the standard procedure for driving around city areas that require 4wd (heavy snow on roads)? Do you turn 4wd off every time you get to a intersection where you need to make a turn?
    I ask because, for the most part, you can take turns a bit wide and be just fine. Some right hand 90-degree turns are a little interesting through. In 4wd, the truck just wanted to keep sliding forward and not make the turn.
    What do you guys usually do? Turn it off at every turn and then turn it back on once going straight?
  2. Jan 28, 2009 at 12:32 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Uhhh...I just keep it in 4WD when I am in snow or for any other reason on city streets that require it. I would think it would be to much of a hassle to swap back and forth from 2WD to 4WD. I know it would be for me!! :eek: But not to sure if it's extra stress on the truck if you do take sharp turns in 4WD, never thought about it.
  3. Jan 28, 2009 at 12:33 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Now I don"t know how everyone else does it, but if I can I take the turn a little wider. But if in traffic I slow down a little more and go into the turn like on a motorcycle. Not cutting the wheels so sharp, and let the truck/tires do all the work.
    Hard to explain but I am sure someone here will chime in on it better than me.
  4. Jan 28, 2009 at 12:37 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Give it a little extra gas to spin the inside tires versus having them do that chirping jumping thing.
  5. Jan 28, 2009 at 12:39 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    If that's the case, it sounds to me like your back wheels were probably pushing you through the turn, and your front tires were sliding, so 4WD may not have even been needed.
  6. Jan 28, 2009 at 12:39 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    The reason why 2wd steers better for you is because the front tires aren't driving/skidding/slipping under power. If you take the same turn in 4wd and hit the gas, depending on the conditions, the front tires will spin, you'll have less control, and the inertia will keep the truck moving forward.
    Take that same turn in 4wd without giving it gas and you'll find that the truck will behave as you've experienced in 2wd.
    My recommendation is to go to a dry dirt field and play around in both 2wd and 4wd to get used to how the truck behaves long before you need to use its abilities in an accident-avoidance situation.
    For now, just adjust your speed to match the conditions and remember that 4x4 will not help you stop quicker. All vehicles are 4-wheel stop.
  7. Jan 28, 2009 at 12:40 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    As longbow said try to make wide turns. Also when on slippery ground the tires are allowed to slip, therefore not causing damage. My $.02
  8. Jan 28, 2009 at 12:43 PM
    SilverSeven
    SilverSeven Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    its not "bad" to take turns, believe me, there are some VERY tight turns in the mountain trails, and you ain't gettin through them in 2wd.
    If you are driving on dry to wet pavement, you shouldnt be in 4x4 anyway, only if there is significant snow.
  9. Jan 28, 2009 at 12:49 PM
    z33tec
    Rochester, NY
    Yeah, I wasn't concerned with damaging anything as there is a significant amount of snow on the roads. Just thought maybe there was a certain technique people used when taking tighter turns in 4wd. I understand when to use it and when it isn't needed though. I generally do not use 4wd, even in snow, unless I think it will be safer for me to do so.
    Thanks for the tips!:thumbsup:
  10. Jan 28, 2009 at 4:14 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I just leave it in 4WD.
    I'm careful not make tight turns, but if/when it ever happens.....I don't 'force' the issue. Sometimes It's better to 'coast' through the turn than apply the gas. Applying gas (torque) is what's hard on the CV joints while turning. In most cases, I'm able to take turns wide enough and not worry. But if I'm pulling into a parking space and the truck starts plowing/bucking (as you mentioned), I'll put it into 2WD and turn into the space that way.
    You just gotta be aware of the situations at hand. If/when the truck starts bucking or plowing - don't force it. Take another approach.
