Talk me out of buying a high milage truck!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by neil_P_smith, Oct 9, 2020.
  1. Oct 11, 2020 at 11:12 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    Neil
    Start with what you're willing to pay max
    Than what you want (AC,DC, 4cyl,6cyl,man,auto ect)
    Go online see what's for sale
    Start with lowest mileage listings (lower the better in my book)
    Research the price on selected trucks
    Go look at the short list trucks
    Inspect for all concerns
    Test drive
    Maybe have a shop do an inspection for you
    Don't be in a hurry
  2. Oct 11, 2020 at 2:54 PM
    Eselhengst
    Eselhengst Well-Known Member
    South of Abbotsford
    2011 Access cab TRD Offroad
    Sway-A-Way 2.0 coilovers and rear shocks Wheelers 8 leaf springs and superbumps ARB front bumper Trail Gear sliders RCI aluminum skids URD Spec-U exhaust etc.
    Your results may vary, but I don’t mind offloading trucks at 200k. It’s not just the motor, that’ll probably last 500k, it’s the starter, alternator, fuel system-injectors, pump, lines, transmission, rear diff, drive lines, transfer case, brakes, radiator, a complicated electrical system, exhaust, suspension and steering. All the little stuff will nickle and dime you to death if the maintenance hasn’t been religious in the past 300k. That said, I plan on keeping my taco until electric trucks are a viable alternative in 10-15 years, but it will still probably be under 350k
  3. Oct 11, 2020 at 7:53 PM
    ImBillT
    ImBillT Well-Known Member
    2010 4x4 base
    Bought an ‘08 4.0 last year with a little over 200k. Replaced the. Carrier bearing and one u-joint to fix drive shaft clunk. Did a trans drain and fill with the garden sprayer. Drained and filled both diffs and the transfer case. It came out as black sludge. I recently replaced a CV, and found a torn stabilizer link boot, and a torn rack and pinion boot. The rack seems to have a small leak. Lost another u-joint. It gets 13-14mpg instead of 16+, in spite of new plugs and plenty of fuel system cleaner. I’m now looking into how to understand fuel trim data to diagnose problems.
    Update: Just today the tachometer started going on and off intermittently, and there’s a sound I’ve been trying to track down that I’m beginning to think my be the A/C compressor. I believe the first two owners of this truck got their money’s worth, and I may be fixing the whole darn thing...which would be okay if planned to keep it, but I bought it to get me by until I find a double-can long before, and feel like I can’t sell it with known problems.
    My 2010 single-cab that I bought with 450mi has had some problems, but I caused them all. The devil you know is better than the devil you don’t know.
  4. Oct 13, 2020 at 6:12 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I don't understand the reasoning in your situation if this one will be the 3rd high mileage vehicle you are seeking. What can this one do that your 93' Toyota can't ?
  5. Oct 13, 2020 at 8:00 AM
    ImBillT
    2010 4x4 base
    The ‘93 Toyota pickup was tiny. Smaller than a first gen Taco, which is smaller than the second gen. It’s hard to fit an American male in those early Toyotas or I would still have one.
    neil_P_smith[OP] likes this.
  6. Oct 13, 2020 at 11:52 AM
    neil_P_smith
    neil_P_smith [OP] New Member
    Yes the '93 is just too small. I live in the PNW and keeping the carpentry, some mechanic tools in the bed even with a canopy is kinda silly. If i can get the bilk of carpentry tools/bags in the cab (stay dry) and some mechanic tools in a bedrail box ill be way better off. Plus i flog the little 22re trying to go any but down hill!! With 300+k i expect to need to replace some things, Ujoints, wheel bearings, ball joints, basic things and the price should reflect that. These are all great comments, Thanks Neil
  7. Oct 13, 2020 at 4:49 PM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    I don't know what to make of this statement. This is like you are saying that you are willing to overpay for a truck that you really don't need. If its cheap and mechanically sound, I have zero issues buying this truck knowing that I will need to set an emergency fund aside for the worse case scenario of a future engine replacement that may or may not occur. It all depends on the price.
