talk to me about front coil springs...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larry, Sep 1, 2012.
  1. Sep 1, 2012 at 8:16 AM
    Larry
    Larry [OP] CARL
    CARL
    I have a set of 4 Bilstein 5100's I need to get installed...I have 4-leaf rear
    I'd like to raise the front, but don't want to destroy the ride. My plan was to set at .85, maybe 1.75.
    I want to maintain some rear rake. no bro for me please.
    as I understand it...the front 5100's load the coils for the lift. not so sure I want to do this?
    what coils would provide a small amount of lift...an inch...inch and half, and allow me to install the 5100's at zero?
    thanks
  2. Sep 1, 2012 at 8:31 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
  3. Sep 1, 2012 at 8:37 AM
    sinaptic
    sinaptic Well-Known Member
    Twin Cities, MN
    2011 Access Cab V6 4x4
    Fog lights, back-up camera, TRD cat-back exhaust, towing package, int. wiper stalk, Weathertech floor liners, color-matched the front bumper and grille, TSB leaf packs, Front Bilstein 5100's at 0", Eibach/Toytec coils (approx 1.25" front lift - sits almost level), rear Bilstein 5100's.
    I have the TSB packs, 5100s on all 4 corners, fronts at 0" with Eibach/Toytec coils. I got about 1.25" out of them, with the rear still sitting about 1" higher. That was perfect for what I was going for.
    All of this stiffins up the suspension quite a bit. I like it that way though; I didn't much care for the mushiness of the stock suspension. I know some folks like it though, so that's something to think about.
  4. Sep 1, 2012 at 8:40 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    If you keep stock coils setting them at .85 you will still have a slight rake, @ 1.75 you will be level...
  5. Sep 1, 2012 at 9:30 AM
    Larry
    Larry [OP] CARL
    CARL
    thanks
    and thanks
    just not sure I want to load the front stock springs. seems, if I'm gonna do it, I should get new coils for a few more bux if there is a set that does what I want.
  6. Sep 1, 2012 at 9:52 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get OME 883's
  7. Sep 1, 2012 at 9:54 AM
    Larry
    Larry [OP] CARL
    CARL
    and the front height will change how much?
    and the ride?
  8. Sep 1, 2012 at 10:01 AM
    OZ-T
    Peter North
    British Columbia
    1 1/2" IIRC , the ride will be less stiff that preloading your stock coils to 1.75"
  9. Sep 1, 2012 at 10:05 AM
    Larry
    Larry [OP] CARL
    CARL
    thanks
    1.5" is pushing me close to bro with the stock 4-leaf.
    but it may be perfect. inexperienced in this area.
  10. Sep 1, 2012 at 10:10 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Aren't the TRD Sports coils non progressive? meaning they wouldn't be affected by pre-load?
  11. Sep 1, 2012 at 10:17 AM
    OZ-T
    Peter North
    British Columbia
    See , that may be true , somebody else said that before , but I wasn't sure
  12. Sep 1, 2012 at 10:18 AM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Jack up the front end until you add 1.5" to the hub to fender measurement and this will give you an idea of what it will look like.
    OR
    Jack it up to the point you like and then measure the hub to fender and compare that to the stock difference. That will give you an idea of the amount of lift you want.
    I have the OME 884's on my 4x4 DCLB 4.0 and I got just under 2" of lift (it had the bro lean until I put in the aal). You can compare length and spring rate of the 883's to the 884's and it should give you some idea of the lift.
  13. Sep 22, 2012 at 6:33 PM
    Larry
    Larry [OP] CARL
    CARL
    follow-up question?...
    Eibach coils vs. OME 883's...
    about the same lift?
    about the same ride?
    also...if I keep the stock springs and set the 5100's at .85, is the ride changed much?
  14. Sep 23, 2012 at 5:29 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    No updated photos of the truck, but I am running the 4 leaf pack, billies all around and the fronts @ 1.75". Looks level, but there is still a slight rake. Rides great, and most who stay below the max setting of these shocks have no issues with alignment or vibration issues :cool:
  15. Sep 27, 2012 at 2:31 PM
    Timfd024
    Timfd024 Active Member
    Tim
    Orlando, FL
    2012 DCab TRD Sport 4x4
    Billy 5100's and 1" rear block. Falken 265/65/18 Wild Peak AT. Audio--Kicker 6x9's and 6.5's hooked to 4ch Alpine. Audiobahn 8's subs to Kicker mono. JVC headunit.
    What did you end up doing? I am in the same boat. I have a 2012 TRD Spt DCSB 4x4 and was thinking of doing billys with stock coils. I only want to lift the front btween 1"-2" and have the best ride possible.
  16. Sep 27, 2012 at 2:44 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The ride won't change much at .85". Currently I have my front 5100s set at 1.75" with stock coils and in the rear I have the 4 leaf TSB pack with a 1.5" AAL. The ride is still pretty smooth and the AAL in the back gives me a nice rake and helps when I am hauling my loaded trailer.
  17. Sep 27, 2012 at 2:48 PM
    Larry
    Larry [OP] CARL
    CARL
    I have not done anything yet. Probably keep the stock springs and set the 5100's @ .85
    I don't want/need to upgrade the rear and don't want to change the ride.
  18. Sep 27, 2012 at 2:55 PM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Thought you were gonna trade for a 5 lug Larry?
  19. Sep 27, 2012 at 2:58 PM
    Larry
    Larry [OP] CARL
    CARL
    never know what the future holds :D
  20. Sep 27, 2012 at 2:58 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I did the 0.85 on my 2WD '09 with the TSB rear leaf pack. It was almost level (slight rake) and I liked the ride and handling much better. It stiffened the front a little and felt more balanced, less "dive" into turns. It wasn't a big difference, just enough to notice. I think you'll be happy with that setup.
