Talk to me about the differences between different styles of Fairleads.
Discussion in 'Off-Roading & Trails' started by Ostrichsak, Jun 30, 2015.
Which Fairlead style do you prefer the looks of?
  1. Picture 1: Roller-style
    9.1%
  2. Picture 2: Solid-style
    90.9%
  1. Jul 2, 2015 at 11:23 PM
    #41
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Technically, IIRC, it's a clevis if it has a safety pin or nut on one end and a shackle if the pin bolts directly into the u shaped piece of metal :D.
    Bolt type shackles are not as safe compared to nut and safety pin clevis's because the bolt can loosen if tension is not kept on the shackle. The safety pin prevents a clevis from coming apart.
    Either way safe use and monitoring of any D-ring type fastener is more critical to everyone getting home safely from a recovery than what type of shackle or clevis is used.
  2. Jul 3, 2015 at 12:36 PM
    #42
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    since we're getting "technical"....THIS is a d-ring
    The proper name for THIS is actually a bow-shackle.
    A clevis refers to something with a pin. So it could be a number of things like these.
    But for the sake of offroad discussion, most of us, myself included use all those terms interchangeably and when almost always referring to the same thing......the bow shackle.
    Benson X likes this.
  3. Jul 3, 2015 at 12:56 PM
    #43
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I usually just call it a cock ring :homer:
  4. Jul 3, 2015 at 1:00 PM
    #44
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    :rimshot:
    Just don't get that thing stuck on there. I doubt there is a nice way to remove a locked up "shackle" from your nether parts.
    OP, did you ever see my question? Any reason other than the last few feet slipping that the source you were talking about wanted the line poked though the drum and duct taped?
  5. Jul 3, 2015 at 3:43 PM
    #45
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    My Warn aluminum hawse is officially for sale if you're interested. :D
  6. Jul 6, 2015 at 7:22 AM
    #46
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Yeah, I'm talking about using the winch when it's been through a couple of days of snow/slush and had the chance to freeze solid over night. The most common use of the winch for me is a self recovery in deep snow. That just happens to be the most likely condition for your line freezing up. Lots of my friends run synthetic line and don't seem to have much issue. BUT, they don't often wheel solo in deep snow.
    Yeah, I really like my thimble... nice and strong. I'd love to see how yours turns out. (a quality bare aluminum finish would look awesome)
  7. Jul 6, 2015 at 11:07 AM
    #47
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    dis ^^^ :D
    that ain't a shackle.......THIS is a shackle!
  8. Jul 8, 2015 at 10:27 AM
    #48
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    I typically go a little larger than what I need. This allows a little bit of a reserve strength. I'd rather have the winch stall before I get close to the strength of my line. Yeah, I know there's all sorts of safety factor built in, but a little more doesn't hurt. You may be able to get an extra wrap or two on the drum with the narrower stuff which would translate into a couple of extra feet of pulling at the winch's maximum power (remember, each layer of line on the drum reduces the load that the winch stalls at). I use a Viking link connector with the extra tail taped onto the drum so that the line wraps over it. The link connector is mostly to help hold things in place for wrapping the drum. You may or may not want a heat shield cover, it depends a lot on how you use your winch and what kind of brake system you have. The Warn M8000 powers out against the brake which creates a lot of heat. If I were lowering a rig down a hill I would go in short steps with a lot of time between steps to keep things cool. Like, five or ten seconds of winching with a minute or two between winching. Winching in I typically don't go more than thirty seconds with a minute or so between. If possible I slack the line between pulls. I use the cool down time to check that things are spooling correctly and that the recovery is going how I want it. I don't treat recovery as a race. I have a nylon cover for abrasion resistance, but it doesn't get used much. If I'm running over a rock or something where that is an issue then I put a recovery damper or heavy tarp material between the line and whatever it's touching.
    A shorter line will allow you to spend more time on the first wrap of your drum (where your winch can pull with the most strength) but a longer line will allow you to reach further. The right length will be dictated by your winching preferences and where you are. In the PNW, I'm rarely more than 50' from a tree. I run an 80' line and carry a 100' extension, along with a snatch block. This gives me a lot of options for getting onto the first layer if need be. The guys I usually wheel with carry extensions as well. I think the longest setup that I've used was my full line with 200' of extensions in order to pull me straight on a straight road with trees lining the sides using a Y arrangement.
