Talk to me about this Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Freeheelbillie, Mar 18, 2018.
  1. Mar 19, 2018 at 6:16 PM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    No, green title is clean here in Michigan. Again, Autocheck and CarFax pulled clean background.
  2. Mar 19, 2018 at 6:21 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Timing chain is fine. They rarely go bad. Water pump is a consumable item along with radiators.
    Price is the same for a rad flush vs just a new rad. $100 give or take for a new aftermarket rad.
    Freeheelbillie[OP] likes this.
  3. Mar 19, 2018 at 6:22 PM
    Public
    Public Member
    2015 Tacoma TRD OR
    Find out something new everyday, thanks for the tip!
    koditten[QUOTED] likes this.
  4. Mar 20, 2018 at 5:24 AM
    Muddinfun
    Muddinfun Well-Known Member
    Make absolutely sure there's no rust holes in the frame. Especially look at the boxed sections near the cats. Since it's from Canada, it's not covered by the US frame waranty extension.
  5. Mar 20, 2018 at 5:51 AM
    koditten
    Kirk
    Central Michigan
    Also check to see if the odometer is in kilometers. It can not be switched to miles.
  6. Mar 20, 2018 at 6:22 AM
    Muddinfun
    There are importing companies that take care of the speedometer conversion. They change the speedo face to have big MPH numbers and convert the odometer to miles. Mine came from Canada and it has a Canadian tach(different text for RPM and cat whisker taillight indicator). I was able to confirm that they did the conversion of the odometer correctly from kilometers to miles.
  7. Mar 20, 2018 at 6:48 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Sounds like you got a good deal,coat the frame when you get it.
