Tall and Skinny MTs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drew02a, Jul 8, 2009.
Keep em or Go Tall and skinny
Poll closed Aug 7, 2009.
  1. Keep BFG AT 265/75/16 (31.5" x 11")
    8 vote(s)
    28.6%
  2. Go BFG MT KM2 255/85/16 (33.1" x 10")
    20 vote(s)
    71.4%
  1. Jul 8, 2009 at 1:04 PM
    drew02a
    drew02a [OP] Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Right now I have 265/75/16 BFG All Terrains.
    My problem is that my truck is pretty light being a 4cyl regular cab, and I think they give me TOO MUCH surface area because I have a tendency to slide in the mud. We're talking unreal amount of sliding. The last time I was in some real mud, I got the tires good and caked. I was kinda turning when I got back on the pavement, and my tires had enough mud/ surface area that I skidded completely sideways (not fishtail, but skid) with no control for a good 20 feet :eek:. They're great in the sand and dirt though.
    It's got me thinking a skinnier tire might be better, also:
    I just re-geared to 4.56 and would like to go taller
    Like the idea of improving gas mileage
    I'm thinking 255/85/16 BFG MT KM2. I hear they handle pretty good on the road, much better than the old Mud Terrains.
    Thoughts?
  2. Jul 8, 2009 at 1:08 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    my 2.5 c
    Regardless of size of tire patch will be same size.
    (wt of truck)/(tire pressure) = (sq inch of tire patch)
    lowering pressure = larger patch
    change tire = change in patch shape
  3. Jul 8, 2009 at 1:09 PM
    drew02a
    San Antonio, TX
    If I jack up the pressure in the tires I have (already preyy high), I'll get alot of wear in the middle.
    The new tires would require less inflation to get a smaller patch. No abnormal wear?
  4. Jul 8, 2009 at 1:10 PM
    HBMurphy
    Paul
    So California Coast
    None
    Also, remember that change in tire diameter will change speedo calibration and therefore falsely change your calculated mpg.
  5. Jul 8, 2009 at 1:11 PM
    drew02a
    San Antonio, TX
    Since I re-geared to 4.56, 33" tires will put my speedo right back where it should be.
  6. Jul 8, 2009 at 1:12 PM
    drew02a
    San Antonio, TX
    Could I get another 1.5c and a vote?
  7. Jul 8, 2009 at 1:14 PM
    HBMurphy
    Paul
    So California Coast
    None
    Yes while 'on road' you would adversely effect the tire wear by abnormally high or low pressure. While off road this is not as big a deal since you are driving at a lower speed and the road is not as consistent as a highway surface. So, adjust pressure for each situation.
  8. Jul 8, 2009 at 1:16 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I say get the MTs.....afterall, you geared for the bigger tire. Should help a little with the sliding. The BFG AT's clog up pretty easy.
  9. Jul 8, 2009 at 1:20 PM
    HBMurphy
    Paul
    So California Coast
    None
    It sounds like your complaint would be best served by buying some deflators (screw them on the valve stem and they deflate your tires to a pre-set pressure). Don't go much below 18 psi 'cause you may break a bead and Really begin to slide!
    Otherwise you may need a lift and that will cost you much more than just a news set of tires. -Hope this helps.
  10. Jul 8, 2009 at 1:22 PM
    HBMurphy
    Paul
    So California Coast
    None
    I would agree but I'm not good about spending others money. :)
  11. Jul 8, 2009 at 1:24 PM
    HBMurphy
    Paul
    So California Coast
    None
    Also, I don't get to play much in the mud - our mud is dry - we call it sand ;-)
  12. Jul 8, 2009 at 1:28 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    IF you are going into mud alot- Then the MT's are the way to go.
    It sounds like the ATs aren't great about clearing themselves out- Maybe look at some other brands?? Cause an MT will probably have more road noise
  13. Jul 8, 2009 at 1:47 PM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    have you compared the spec tire weight of each size?
  14. Jul 8, 2009 at 2:05 PM
    TIM GAINOUS
    TIM GAINOUS Well-Known Member
    tallahassee fl
    o7 base desert sand
    tints,venvisors,low pro toolbox, readylift sst ,afe pro dry,dynomax muffler,sec air filter removed. jvc aresenal, with rear jvc 6x9's front blaupunkts.
    Bfg at's are my favorite tire ive had several sets over the years. They however suck in mud. I have em on my 90 4x4 chevy. This the second set on this truck. If you stay in very light mud or sand they're excelent. They also have very good road manners with minimal noise. Go for the mudders
  15. Jul 8, 2009 at 3:39 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Like it's been said. You're complaining cause an All Terrain tire caused you to slide in mud? Would you also complain about summer tires being shit on ice?
    Not trying to be a dick, but stick to what you want the tires to do. All terrains aren't made for heavy mud.
    That being said you already regeared so it sounds like you already have your mind made up.
  16. Jul 8, 2009 at 3:44 PM
    djs05tacoma
    djs05tacoma Well-Known Member
    Martinez, CA
    05 Double Cab TRD offroad 4x4
    3" OME Lift, 285's
    It sounds like part or most of your sliding problem is from your tires not clearing out the mud, maybe not so much surface area? :notsure:
    That said I'd say go with the MT. The difference is night and day in mud from an AT to MT.
  17. Jul 8, 2009 at 4:45 PM
    drew02a
    San Antonio, TX
    Well, I re-geared for the tires I have now and left a little room for bigger ones down the road. Just trying to get some opinions on sizes and treads.
    I can understand that these tires aren't the best IN mud, but I don't think any tire should let you slide that much on pavement no matter how much mud is caked in there.
  18. Jul 9, 2009 at 9:30 AM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    ya go km2
