Tall Floor Jack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco John, Dec 6, 2009.
  1. Dec 6, 2009 at 2:14 PM
    Taco John
    Taco John [OP] Well-Known Member
    Illinois
    4X4
    I came across a decent price on a floor jack that has a max 21" lift height. Is that tall enough to let me lift the front of a 09 4x4 w/o having to crip it up? It would make things sooooo much faster for me vs. using my shorter jack.
  2. Dec 6, 2009 at 2:44 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Should do. You won't get much lift off it though. Depends if you want it just to change the oil, or do you plan on taking tires off? With 265x75 tires I barely have an Inch of clearance to take my tires off with the down travel of my stock suspension.
  3. Dec 6, 2009 at 2:58 PM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    I have a two ton napa floor jack. I just went out and raised it all the way up and measured it at 21" also.
    I have a 2WD pre-runner and so far all I have used it for on mine is to rotate tires. I jack on the center of the frame and it has enough travel to raise both wheels off the ground enough to get them off. I do not have any lift or 5100s, just the factory bilsteins and 16" tires.
    HTH
  4. Dec 6, 2009 at 3:01 PM
    flatlander
    That's some good info to know Krazie. My future upgrades will be that size tire and then eventually some 5100s. Man, I don't know if even using jackstands is going to help me rotate at that point.
  5. Dec 6, 2009 at 3:03 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    That's really where my issue is too is the Jackstands not being big enough. I might have to get his and her jack stands. One for the Jeep and one Tacoma.
  6. Dec 6, 2009 at 5:07 PM
    Taco John
    Illinois
    4X4
    Sounds like what I am looking for, then. I just measured my 2 ton and it tops out at 13"... Fits nicely under the wife's car that has the opposite problem, though.
    I believe the pre-runner and te 4X4 have the same stance so I think I will give it a try.
  7. Dec 6, 2009 at 7:16 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I have a 4x4 TRD OR with 5100's and 265/75/16 tires.
    My 3 ton floor jack has a maximum height of 19.75" - and I don't come close to maxing it out.
    For the rear set the jack on the center of the rear end (bottom of rear end).
    For the front there is a jacking point near the oil pan. Can't miss it. Its between the two skid plate for anyone who has the Off Road. If you don't have the Off Road, its just behind your front skid plate.
    Both locations can get my tires several inches off the ground without maxing out the jack.
  8. Dec 6, 2009 at 7:55 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Does anybody know of a 3 ton that goes above 21"? with my 4" spindles, coilovers and 285s it seems to barely get it off, it would be nice to get a lttle more if possible.
  9. Dec 6, 2009 at 8:27 PM
    1BlkT
    Ty
    90603
