Talladega National Forest Ride and Camp - June 9 & 10
Discussion in 'South East' started by BamaTaco56, Apr 12, 2018.
  1. Jun 7, 2018 at 8:02 AM
    #301
    BamaTaco56
    BamaTaco56 [OP] Well-Known Member
    Trey
  2. Jun 7, 2018 at 8:06 AM
    #302
    Quadabaum
    Quadabaum Well-Known Member
    2017 Tacoma TRD OR 4x4 DCSB
    265/75R16 Falkens, ADS 2.5" Stage 3 Suspension, Go Fast Camper
    Will there be a need to air down or anything? I am guessing we will stop at the trail head, set the rigs, cb radios, and then head out.
  3. Jun 7, 2018 at 8:08 AM
    #303
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    I kinda doubt you'll need to air down, but may want to for a little comfort depending on what you run at.
    I run at 40 so I'll probably drop to like 30
  4. Jun 7, 2018 at 8:10 AM
    #304
    BamaTaco56
    Trey
    Airing down a little will make the ride better as Scotty said. We will have to get on pavement to go from 600-1 to 600-2 I believe, so you wouldn't want to go too low
    stronghammer likes this.
  5. Jun 7, 2018 at 8:32 AM
    #305
    TRD Tyler
    TRD Tyler Straightenin the curves. Flattenin the hills
    Athens
    16 DCSB 4WD TRD OR
    I'm going to go to Anniston Friday to drop off my son at my parents house. I'll just meet you guys in Sylacauga.
    stronghammer[QUOTED] likes this.
  6. Jun 7, 2018 at 8:34 AM
    #306
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    alright man sounds good, looking forward to meeting you.
  7. Jun 7, 2018 at 9:07 AM
    #307
    Quadabaum
    I am at ~33 front 30 rear so ill stick around there and adjust if needed. .
  8. Jun 7, 2018 at 9:41 AM
    #308
    BamaTaco56
    Trey
    Scotty doesn’t care about his tires enough to run correct pressure
    Quadabaum[QUOTED] likes this.
  9. Jun 7, 2018 at 9:42 AM
    #309
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    40 is correct. got 50k miles on my BFGs at this point.
    come at me bro.
    JBTacoma and Quadabaum like this.
  10. Jun 7, 2018 at 9:46 AM
    #310
    BamaTaco56
    Trey
    Chalk tested?
  11. Jun 7, 2018 at 9:47 AM
    #311
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    nope, but you gonna question 50k miles on tires that aren't even rated for that and I've got more to go?
  12. Jun 7, 2018 at 9:50 AM
    #312
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    let me correct that. 45k miles. I put them on at roughly 108k and I'm at 153k.
    tires probably have a good 10k left. they've been on since before I joined TW.
  13. Jun 7, 2018 at 10:27 AM
    #313
    Quadabaum
    My tires seem like a low pressure but thats what the chalk said. I even retested because i didnt trust it. Those are "warm" pressures also.
  14. Jun 7, 2018 at 11:03 AM
    #314
    BamaTaco56
    Trey
    Mine are 32 ish front and 30 ish rear unloaded per chalk test
  15. Jun 7, 2018 at 11:04 AM
    #315
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    are yours load range E? I've also got quite a bit more weight than you.
  16. Jun 7, 2018 at 11:10 AM
    #316
    BamaTaco56
    Trey
    Yes, mine are E rated
  17. Jun 7, 2018 at 11:12 AM
    #317
    BamaTaco56
    Trey
    Wouldn’t “correct” pressures be lower for E rated tires?
  18. Jun 7, 2018 at 11:12 AM
    #318
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    :notsure:
    40 has worked for me so that's what I'll stick with lol.
  19. Jun 7, 2018 at 11:13 AM
    #319
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    they have a higher max pressure so I would assume they have a higher running pressure as well.
  20. Jun 7, 2018 at 11:14 AM
    #320
    BamaTaco56
    Trey
    Stronger sidewall = less flex = less pressure required for an even contact patch
    My train of thought
