Taller tire = more comfort?
Discussion in 'Wheels & Tires' started by Volatov, Mar 15, 2017.
  1. Mar 15, 2017 at 7:16 PM
    Volatov
    Volatov [OP] Well-Known Member
    Ev
    2020 TRD Pro
    Currently sporting 265/60R18 stock Michelins on Limited wheels with a 2016 taco. I got 5100 installed with about 1.5" lift and my ride is relatively stiff (a bit stiffer than stock). I'm thinking of stepping up to 275/70R18 or something similar to acquire extra side wall for more comfort. Would this equalize some of the bumpiness on the roads or should I consider a different path?
  2. Mar 15, 2017 at 8:38 PM
    Markc1024
    Markc1024 Well-Known Member
    The more sidewall, the better. You may need to compromise on the width to keep overall diameter down. Maybe 265/70 or 255/75
  3. Mar 15, 2017 at 8:48 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Did you get different springs? Or just use the 5100 clips? Using the clips will cause a stiffer ride.
    Your stock tires are likely P-load, which is the softest riding and lightest. If you go to a different tire, pay attention to load rating. Going to a heavier load, especially E-load will have a firmer ride.
