Tallest lift without extending drive and brake lines
Discussion in '3rd Gen. Tacomas (2016-2023)' started by toyotatacomaSJ, Dec 10, 2017.
  1. Dec 10, 2017 at 9:08 PM
    toyotatacomaSJ
    toyotatacomaSJ [OP] Member
    I am looking to see what is the tallest lift I could put on my truck without having to mess around with the driveline or brake lines on my truck. Would it be a 3 or 4 inch lift?
  2. Dec 10, 2017 at 9:13 PM
    tcjacado
    tcjacado Well-Known Member
    Pretty sure no more than 3 inch lift. Any higher and you will need new brake lines. My truck sits around 5 in the front and about 4 in the back. I still need to extend my rear lines and also need to get extended travel for the shocks.
    toyotatacomaSJ[OP] likes this.
  3. Dec 11, 2017 at 8:00 AM
    toyotatacomaSJ
    If I did the OME lift 2", and did a 1" body lift, no need to extend brake lines? Not able to find any good 3" lifts.
  4. Dec 11, 2017 at 8:10 AM
    techman993
    techman993 Well-Known Member
    Allen
    Pittsburgh, PA
    2018 Cement Tacoma TRD OR
    Tinted Windows B-pillar vinyl delete Tyger Step-Tubes Tailgate decals (Thanks @rrentop!) Boss 2" lift 285/70/R17 Nitto Terragrapplers TRD PRO Rims
    No need to extend if you keep it less than 3". Check out Toytec suspension lift if you haven't already. Body lifts I would try to avoid for the fact it will make your ride quality a bit shotty.
  5. Dec 11, 2017 at 8:33 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    3" is pushing the limit of stock components/front driveline angles if you have a 4WD. I already blow CV boots and I am pushing 2.5" or so. Just stick with the standard 2-2.5" stuff, you can clear 285's (33") without much issue or none at all.
    2WD you have little to no issues with lifting because there is no front drive components. I would do a spindle lift to get 3-4" easy and call it a day.
    I also put extended rear brake lines with the extended length Bilstein shocks and the dakar heavy EL springs. Looks like you need them when you droop out.
    Definitely avoid body lifts.
