Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Sep 25, 2015 at 7:33 AM
    #2701
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    Try the Florida classifieds on here.
  2. Sep 25, 2015 at 8:17 AM
    #2702
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I posted this in the classified thread but thought I'd put it in here too.
  3. Sep 25, 2015 at 9:22 AM
    #2703
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Mod day October 3rd anyone? I'm looking to do my front end lift, OME struts with springs on and LR UCAs
  4. Sep 25, 2015 at 9:27 AM
    #2704
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
  5. Sep 25, 2015 at 9:38 AM
    #2705
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Not sure yet, gotta go back to the hunting property at some point before the season starts. We may do that on the weekend of the 10th though but not 100% positive on that.
  6. Sep 25, 2015 at 9:45 AM
    #2706
    Taco No Baka
    Lee
    Tampa, FL
    Hmm...I was thinking we might get more help for Frank if we had his mod day at your place, since most of the active members around here live on that side of the bay (You, Phil, Rick, Nam, Seth, etc...).
  7. Sep 25, 2015 at 10:01 AM
    #2707
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    If I'm available & the other half doesn't have a problem with it I'm more than happy to host again.
  8. Sep 25, 2015 at 10:08 AM
    #2708
    Taco No Baka
    Lee
    Tampa, FL
    If not then we can do it at my place. It shouldn't be a big deal except for the UCAs. Never done them but they look like they could elicit a few foul words before they are installed. :eek: Otherwise, we could probably get the coilovers removed and replaced in an hour or so.
  9. Sep 25, 2015 at 10:28 AM
    #2709
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I've never done uca's either. I remember reading something on TW about uca's & it said to have extra bolts cuz they may need to be cut, I don't know how true that is though. I believe it said the front bolt is the hardest to get out.
  10. Sep 25, 2015 at 10:30 AM
    #2710
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    i recall reading the same about the uca bolts too
    SpruceTaco likes this.
  11. Sep 25, 2015 at 12:18 PM
    #2711
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    Fellas it's only one bolt per side and the biggest pain in the ass is getting the bolt out you will need to bend a part of the inner fender or take out body mounts and Jack it up
  12. Sep 25, 2015 at 12:21 PM
    #2712
    taco8603
    taco8603 Well-Known Member
    Philip
    Kenneth city Florida
    2019 White Tacoma DCSB SR 4x4
    lt265/75/16
    Where at
  13. Sep 25, 2015 at 12:27 PM
    #2713
    Taco No Baka
    Lee
    Tampa, FL
    @taco8603 Either at Spruce's or my place. TBD.
    BTW, how do you like running swaybar free?
  14. Sep 25, 2015 at 12:28 PM
    #2714
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I couldn't remember if it was one long bolt or 2 smaller ones but do remember reading it is a pain in the ass.
  15. Sep 25, 2015 at 12:30 PM
    #2715
    michaelrussell
    Michael
    belleview,FL
    Yeah it's only one and changing them isn't that bad but getting that darn bolt in and out is problem
  16. Sep 25, 2015 at 12:43 PM
    #2716
    taco8603
    Philip
    lt265/75/16
    It's okay now I'm thinking of tires but I don't know what size I'm gonna go with I have 265/75/16
  17. Sep 25, 2015 at 12:45 PM
    #2717
    taco8603
    Philip
    lt265/75/16
    But I'm going to wear these tires out first maybe I'll get wheel spacers
  18. Sep 25, 2015 at 12:50 PM
    #2718
    michaelrussell
    Michael
    belleview,FL
    Thornbirds
  19. Sep 25, 2015 at 12:52 PM
    #2719
    Taco No Baka
    Lee
    Tampa, FL
    Unless you get new wheels, you're probably going to have to run wheel spacers if you get any wider a tire. As I recall, you were pretty close to rubbing on your UCA.
    Again...have you noticed much difference now that you deleted the sway bar?
  20. Sep 25, 2015 at 12:55 PM
    #2720
    Taco No Baka
    Lee
    Tampa, FL
    Then you can call him "mini-me", lol. Nitto Trail Graps, or something made by Interco (i.e.: Thornbirds, Swampers, etc...).
