Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Dec 16, 2015 at 8:52 AM
    #3261
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    50/50 chance good choice lol
    TAC1 likes this.
  2. Dec 16, 2015 at 8:52 AM
    #3262
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    @Rattletrap66 check here haha
    TAC1[QUOTED] likes this.
  3. Dec 16, 2015 at 8:59 AM
    #3263
    Hugopreston
    Hugopreston Well-Known Member
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    McGee tire in Valrico.
    TAC1 and Rattletrap66[QUOTED] like this.
  4. Dec 16, 2015 at 9:03 AM
    #3264
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    nice, when are you going? I live on in Brandon nearby
  5. Dec 16, 2015 at 11:14 AM
    #3265
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Well, I finally got the OGT buttoned back up today. Changed the oil and put the skid plate back on. The only outstanding maintenance items left are the carrier bearing and a new steering rack guide, both of which are ~$80 each in parts. :annoyed:
    TAC1 and Rattletrap66 like this.
  6. Dec 16, 2015 at 11:46 AM
    #3266
    Hugopreston
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    I'm heading out there now.but gotta meet up with a buyer for my stock wheels first. Text me 813-400-7858
  7. Dec 16, 2015 at 11:55 AM
    #3267
    SilverJack
    SilverJack no one
    It's supposed to be a standard, but not something you can enforce. Tire manufacturers are in different countries.
    Check the other side of the tire to see if they installed the tires to hide the markers.
    http://www.tirebusiness.com/article...s-those-color-coded-sidewall-markings-serve-a
    The other issue may be a tire that is out of round. I went through this with a set of Yoko Geolanders that just would not run smooth. I was lucky and they were returned under a "try before buy" warranty. I replaced them with Michelins and never looked back. I also had issues with Cooper tires, but that was a long time ago. Sometimes you get a bad set of tires and you just have to try something else. I know it's a pain to remove and remount them, but stuff happens. If a tire is bad enough that it can't be balanced (using a normal amount of weights), then anything short of shaving won't help the problem.
    TAC1 likes this.
  8. Dec 16, 2015 at 1:28 PM
    #3268
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
  9. Dec 16, 2015 at 1:29 PM
    #3269
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Awesome. I hope they are as good as they sounded on the phone. Good luck and keep us posted
  10. Dec 16, 2015 at 1:33 PM
    #3270
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    thanks man!
  11. Dec 16, 2015 at 1:58 PM
    #3271
    Hugopreston
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    Well they refused to try and road force them saying that won't do anything. And they are between 4-8oz Each. Which I guess is better than the 16+oz tires plus had them at. 1 wheel didn't even have weights put on at TP.
  12. Dec 16, 2015 at 2:19 PM
    #3272
    Hugopreston
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    Apparently that's the wrong price. They honored it but it's supposed to be more for bigger tires.
  13. Dec 16, 2015 at 2:44 PM
    #3273
    Taco No Baka
    Lee
    Tampa, FL
    Bummer. :(
    TAC1 likes this.
  14. Dec 16, 2015 at 3:14 PM
    #3274
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Wow! Sorry to hear that man. Good news on needing less weight though. How's she riding?
  15. Dec 16, 2015 at 3:15 PM
    #3275
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    I know that certain services are cheaper up there than down here but it did seem rather cheap. I thought they might've had a special
  16. Dec 16, 2015 at 3:27 PM
    #3276
    Hugopreston
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    well it went down about 10oz per wheel so it rides ALOT better. Feels a lot lighter and rides smooth until about 75-80mph then a small vibration begins. However, I never go over 65-70 when I'm in the truck so for now I'm satisfied I guess lol.
    TAC1[QUOTED] and Soul Surfer like this.
  17. Dec 16, 2015 at 4:06 PM
    #3277
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Well, that's not too bad I guess. Maybe the tires will smooth out a bit more after some use.
  18. Dec 16, 2015 at 4:08 PM
    #3278
    Timbo's Customs
    Timothy
    Lakeland FL
    @Hugopreston did they rotate the tire a bit and rebalance or just rebalance them
    TAC1 likes this.
  19. Dec 16, 2015 at 4:10 PM
    #3279
    Hugopreston
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    No they refused to rotate the tires at all due to fear of messing up the custom wheels lol. So they just rebalanced them.
    TAC1 likes this.
  20. Dec 16, 2015 at 4:31 PM
    #3280
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Due to fear of scratching the wheels?!?! That's ridiculous. The 1st shop that I found deals with commercial sized tires so I can understand them not having the plastic part that clips on to the arm which is used to dismount/mount the tires but these guys? I asked if they could rotate the tires on the wheels if needed & they said yes. I can understand that if you are dealing with 245/35r21's (I sold 4 of those today for $2040 on a Tesla & they are a BITCH to install) but your tires have enough sidewall flex to not force the machines arm into the wheel & gouge it.
    Wow. Glad you felt an improvement but that's pretty crappy. Maybe that would've been the little bit of adjustment needed to have your truck 100% smooth.
    Do you have any warranty that allows you to return for re-balancing?
