Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Jan 8, 2016 at 4:52 PM
    #3521
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    hey, going to key club bake sale is not called work....
  2. Jan 8, 2016 at 5:13 PM
    #3522
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Pretty big areas around lakeland to do it but that's a drive for the ogt
    allenfab likes this.
  3. Jan 8, 2016 at 5:17 PM
    #3523
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    :pccoffee:
    Haha, sorry, burning the midnight oil coupled with the weather caught up to me. :oops:
    Anyway, yeah, like @Timbo89 said, the tube is already grounded to the chassis so there's no need to run an additional ground wire. Effectively, the tube is part of the chassis. But yes, some bare metal where the stud attaches to the mount would be beneficial, although to be honest, I didn't make any special effort to remove any paint when I mounted mine. That said, I also didn't repaint the hole after I drilled it. I did however, check that the ground terminal on the coax had continuity with the chassis before I buttoned everything up and installed the radio.
    Your radio mounting location is as good as any, probably better than some since the speaker isn't really obstructed. I have mine mounted to the headliner above the rearview mirror...yes, it's mounted ONLY to the headliner. I put a fairly good sized aluminum plate on the top side to screw the mounting bracket into and it actually seems like a pretty stout mount. It doesn't seem to shake or vibrate anymore than any other mount I've seen.
  4. Jan 8, 2016 at 5:20 PM
    #3524
    Taco No Baka
    Lee
    Tampa, FL
    And even more of a drive for Travis, lol.
    Didn't we decide on doing this at Bass Pro Shops (I75 & SR 60) though?
  5. Jan 8, 2016 at 5:21 PM
    #3525
    TAZ2014Taco
    TAZ2014Taco Well-Known Member
    Florida
    2019 Tacoma 3.5 SR5
    Yep I'll drive to bass pro
  6. Jan 8, 2016 at 5:24 PM
    #3526
    Timbo's Customs
    Timothy
    Lakeland FL
    Yes sir
  7. Jan 8, 2016 at 5:26 PM
    #3527
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Awesome, thanks! I left some bare metal on the bottom of the tab and the hole is also still bare from where I drilled. All should hopefully work good. Just need to pick up some zip ties to clean up how the coax is ran.
    Is yours wired straight to the battery, or is it wired to the cig lighter or even a tapped wire from behind the dash? Is it on a switch?
    Timbo's Customs likes this.
  8. Jan 8, 2016 at 6:17 PM
    #3528
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Cig light for me, just plug and play with an adapter
    TAZ2014Taco likes this.
  9. Jan 8, 2016 at 6:19 PM
    #3529
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Paint
  10. Jan 8, 2016 at 6:29 PM
    #3530
    allenfab
    Todd
    Lakeland, FL
    mehh, my cig lighter doesn't work, and I haven't wired up my new one yet :D
    Maybe I can do some of this stuff at @Timbo89 house this Sunday while I supervise, if that is still scheduled
  11. Jan 8, 2016 at 6:32 PM
    #3531
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I did an add a fuse & tapped into the fuse panel. I don't have a switch, just use the on/off on the radio.
  12. Jan 8, 2016 at 6:35 PM
    #3532
    allenfab
    Todd
    Lakeland, FL
    Come to think of it, I have 5 open non-relayed terminals coming off my Bussman fuse/relay box that I have already forgot about. I will just run power from that and use the fuse built into that.
    Sometimes my brain just doesn't work lol
    Taco No Baka[OP] likes this.
  13. Jan 8, 2016 at 6:41 PM
    #3533
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    That's why we're here, to help each other when our brains don't work. Haha
  14. Jan 8, 2016 at 6:43 PM
    #3534
    Timbo's Customs
    Timothy
    Lakeland FL
    Sure thing man. @Rattletrap66 you still coming over? @allenfab you have any 3/16 or 1/8" small plate in the scrap pile?
    allenfab[QUOTED] likes this.
  15. Jan 8, 2016 at 6:46 PM
    #3535
    allenfab
    Todd
    Lakeland, FL
    I have no 3/16" plate but have a ton of 1/8" plate. How much do you need?
  16. Jan 8, 2016 at 6:48 PM
    #3536
    Taco gator
    Taco gator Taco with 6.5" front 0" rear lift
    J.D.
    Lakeland, FL
    2014 2wd Taco
    6.5" Spindle/5100 lift front lift
    Very funny Nam
  17. Jan 8, 2016 at 6:52 PM
    #3537
    Timbo's Customs
    Timothy
    Lakeland FL
    A few pieces in the area of 8"x2.5 to 3"wide little strip hahah. Need 2
  18. Jan 8, 2016 at 6:53 PM
    #3538
    Taco No Baka
    Lee
    Tampa, FL
    Mine goes right to the battery (although it's fused at the battery). When I installed it I was kinda being lazy and I didn't feel like looking for an always-hot wire to tie into. I figured I'd want to monitor the radio when the truck might be parked, so I didn't want to have to have the key on to power the radio.
    Haha, i was going to say though about your nice aux fuse panel. That's perfect for this. :thumbsup:
    Oh, and your ground should be cool. If you have any doubts, just check it with a multimeter to make sure you have good continuity between the radio-side ground on the coax and the chassis. If you do, then you're golden.
  19. Jan 8, 2016 at 6:58 PM
    #3539
    allenfab
    Todd
    Lakeland, FL
    I've got a 4'x4' sheet of it, so i can cut to exact size. which width would work better for ya?
  20. Jan 8, 2016 at 6:59 PM
    #3540
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    Thanks for the invite nam but I'm working!
