Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Mar 31, 2016 at 6:12 PM
    #5501
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
  2. Mar 31, 2016 at 6:18 PM
    #5502
    SilverJack
    SilverJack no one
    True, my friend owns a body shop and he uses it all the time. It is a much better cleaner than physically buffing the surface.
    But, he uses it to clean before painting or to remove overspray. Acetone is used in paint as a volatile component to keep the paint in suspension until the carrier agents dry out, then the paint sets. Basically, it's a mild paint thinner. Great stuff, but unless you are working with a specific mixture and know what you are doing, you could make a mess of your clearcoat.
    Hugopreston likes this.
  3. Mar 31, 2016 at 6:26 PM
    #5503
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Lesson has been well learned. In the middle of the words with a fire in my truck lol. But I'm going to re wire it with an inline switch and bigger gauge wire
  4. Mar 31, 2016 at 8:39 PM
    #5504
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    Smart idea. Or get a wire harness for $15 from a website if you don't like wiring.
    http://www.caliraisedled.com/product/2-leg-wire-harness-for-pods
    SpruceTaco likes this.
  5. Mar 31, 2016 at 8:42 PM
    #5505
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
  6. Mar 31, 2016 at 8:44 PM
    #5506
    1stgen
    18 SR5
    Lol that's what happens most of the time. Some people have to learn from their mishaps. I just got done installing a fuse block that literally took me 10 hours but now all my wiring is organized and has individual fuses.
  7. Mar 31, 2016 at 8:45 PM
    #5507
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Run a relay, always run a relay for fogs, led bars or pods. I use 12 GA and have a cat 5 cable running to my switches all they do is trigger the relay and it handles up to 40 amps.
    White Horse likes this.
  8. Mar 31, 2016 at 8:47 PM
    #5508
    Timbo's Customs
    Timothy
    Lakeland FL
  9. Mar 31, 2016 at 8:48 PM
    #5509
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I want to do that one of these days. Got my eye on the 12 circuit Blue Sea fuse block. But for now everything has an inline fuse & I used harnesses with relays for both my light bar & pods.
  10. Mar 31, 2016 at 9:13 PM
    #5510
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Sh...
    1stgen likes this.
  11. Apr 1, 2016 at 7:48 AM
    #5511
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    :D
  12. Apr 1, 2016 at 8:34 AM
    #5512
    Av8er
    Av8er Well-Known Member
    Taylor
    Formaly Houston, now Tampa, FL.
    09 Prerunner SR5/TRD DC, LB, w/ Tow
    Hey fellas! Happy Friday!
    Couldn't find much when I did a quick local search on here so figured I'd cut to the chase. Who do you guys trust around here to mount and balance (properly) a new set of BFG AT's 265/70/17? Stock rims and no lift (yet). I have the tires on order already just need the service done.
    Thanks for any recommendations and ya'll have a great weekend.
    Rattletrap66 likes this.
  13. Apr 1, 2016 at 10:00 AM
    #5513
    1stgen
    18 SR5
    Mines still pretty messy lol compared.
  14. Apr 1, 2016 at 10:05 AM
    #5514
    Timbo's Customs
    Timothy
    Lakeland FL
    I hate trying to figure out what wire is what so I try to be pretty neat so I can glance at it to find a problem
  15. Apr 1, 2016 at 12:31 PM
    #5515
    1stgen
    18 SR5
    I only have three things so I know what wire goes to what.
  16. Apr 1, 2016 at 12:37 PM
    #5516
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Tire Kingdom has been good for me, Tampa off 301 and Palm River Rd or in Valrico are the locations I have been
    TwoTrack likes this.
  17. Apr 1, 2016 at 1:29 PM
    #5517
    TwoTrack
    TwoTrack Well-Known Member
    Clint
    Tampa, FL
    2005 Tundra 4x4
    Same shop has done a decent amount of work for me too. Never had a problem.
  18. Apr 1, 2016 at 6:50 PM
    #5518
    1stgen
    18 SR5
  19. Apr 1, 2016 at 6:53 PM
    #5519
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Looks good, wasn't too hard was it?
    1stgen[QUOTED] likes this.
  20. Apr 1, 2016 at 7:55 PM
    #5520
    1stgen
    18 SR5
    Thanks, only took me 2 hours lol.
