Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Apr 1, 2016 at 9:25 PM
    #5521
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Well it takes time to run wires & do It clean.
  2. Apr 1, 2016 at 10:36 PM
    #5522
    birdman076
    birdman076 Well-Known Member
    Hudson, FL
    2015 DCSB SR5 PreRunner 4x2
    Bull Bar, 4" SS Side Steps, LED Bulb Replacements Throughout, Tri-Fold Tonneau Cover, T-Rex SS Grill Inserts
    The other thing you can do for the light bars/ leds is step them up to 24vdc. Most light bars are rated for up to 32vdc. They run cooler as they do not pull as many amps at higher volts. I run my el'cheapo 27w off road floods at 24vdc with a step up converter. Had them on the truck over a year now and no issue once so ever. We make our own LED systems at work and build the drivers in house as well so we do a lot of testing and have played around with a lot of the "Cheap" LED bars from Amazon. Biggest thing we found is little to no driver circuitry on some of the very cheap ones and they are extremely inefficient. Got a 20" light bar off amazon that pulls 10 amps at 12vdc, however it pulls under 6amps at 24vdc. We will probably build a driver for that one or I'll get a "High Power" dc step up converter and run them as is. for $20 i'm not so worried about it.
    Using this one currently in my harness for my 27w floods. http://www.electrodragon.com/product/xl6009-step-dc-boost-adj-module-4a/
    The El'Cheapo 27w lights. I got them when they miss marked them and had 2 for $12. Surprisingly Shanren's lights are pretty damn good quality with drivers on all of the ones we have messed with. These pull like .35amps each @ 24vdc.
    http://www.amazon.com/SHANREN-Light..._UL160_SR160,160_&refRID=0ZCQ9S55NK7F995Z9TQK
  3. Apr 2, 2016 at 5:30 AM
    #5523
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Got some surface rust starting on my frame. Anything to worry about?
  4. Apr 2, 2016 at 6:08 AM
    #5524
    TAZ2014Taco
    TAZ2014Taco Well-Known Member
    Florida
    2019 Tacoma 3.5 SR5
    I'd light sand and spray it with rustoleum performance enamel, a lot of my frame is sprayed with that
    Scoobarooo[QUOTED] likes this.
  5. Apr 2, 2016 at 6:11 AM
    #5525
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    I was planning on it, I was just wondering. This is the last year I qualify for the frame rust replacement
    TAZ2014Taco[QUOTED] likes this.
  6. Apr 2, 2016 at 6:25 AM
    #5526
    TAZ2014Taco
    Florida
    2019 Tacoma 3.5 SR5
    I didn't even know that was a thing, if it's free why not lol
  7. Apr 2, 2016 at 6:53 AM
    #5527
    Av8er
    Av8er Well-Known Member
    Taylor
    Formaly Houston, now Tampa, FL.
    09 Prerunner SR5/TRD DC, LB, w/ Tow
    RattleTrap and Two Track, thanks a lot fella's. Appreciate the info. Tire Kingdom it will be.
  8. Apr 2, 2016 at 6:54 AM
    #5528
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    My frame has the same thing, if it doesn't look deep just do what was said above if you didn't want to worry about getting the whole thing replaced.
  9. Apr 2, 2016 at 11:50 AM
    #5529
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Pretty sure it's at Toyota's discretion as to whether they'll replace the frame and I doubt a little surface rust would prompt them to do it. It probably has to be completely rusted through before they would consider it. Could be wrong but who knows?
    Scoobarooo likes this.
  10. Apr 3, 2016 at 4:15 PM
    #5530
    Kurupt
    Kurupt Well-Known Member
    Max
    Tampa, FL
    13 SSM 4x4 TRD OR
    Debadged, 3" Icon lift, Icon UCA.
    Most dealerships require a hole in the frame plus I don't think Florida trucks qualify.
  11. Apr 3, 2016 at 4:35 PM
    #5531
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    I know of two frame replacements here in pinellas. I would have Toyota look at it , and document there findings. Might come in handi some day.
  12. Apr 3, 2016 at 4:37 PM
    #5532
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Sounds good to me haha
  13. Apr 3, 2016 at 5:01 PM
    #5533
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    doesn't hurt to have toyota look at it for your piece of mind, but i'm almost certain it's going to be a waste of your time, surface rust is nothing, if you google rusty frame tacoma you'll see some real rust
    Scoobarooo and Hugopreston like this.
  14. Apr 3, 2016 at 7:12 PM
    #5534
    Taco No Baka
    Lee
    Tampa, FL
    Thinking about it, if your truck hasn't been in for the frame recall, if you take it in, I think they were coating the frames that weren't bad enough to scrap with a corrosion inhibitor, but I could be wrong about that.
  15. Apr 4, 2016 at 9:26 AM
    #5535
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Well, me and my girlfriends dad re wired the light bar today. Added an Inline fuse and wrapped all of it in loom. Looks like it came from the factory
    1stgen likes this.
  16. Apr 4, 2016 at 9:31 AM
    #5536
    1stgen
    18 SR5
    Good idea, you coming to a meet soon?
  17. Apr 4, 2016 at 9:36 AM
    #5537
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    I need too, girlfriend wouldn't be too enthused to come out. Haha.
  18. Apr 4, 2016 at 9:39 AM
    #5538
    1stgen
    18 SR5
    This Sunday is tamlando in lakeland
    White Horse likes this.
  19. Apr 4, 2016 at 10:39 AM
    #5539
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
  20. Apr 4, 2016 at 10:42 AM
    #5540
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Yeah now my wife wants me to start a FB cause she don't want to deal with all the questions. Haha
