Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Apr 5, 2016 at 3:20 PM
    #5561
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Is there a pop up that gives you the choice to charge only or use it for media?
    Scoobarooo likes this.
  2. Apr 5, 2016 at 3:39 PM
    #5562
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Ok so for the Pinellas guys going to Tamlando, meet 9:30 at the Publix on Carillon parkway. We'll head to the Hardrock shortly after.
    120 Carillon Pkwy, St. Petersburg, FL 33716
    kelz33 and Soul Surfer like this.
  3. Apr 5, 2016 at 3:42 PM
    #5563
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    What would you guys use to secure a 100A fuse for a subwoofer to the firewall without drilling? It's in a location where drilling is not an option. Would you guys trust Velcro or some 3M heavy duty double sided tape?
  4. Apr 5, 2016 at 3:56 PM
    #5564
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    :thumbsup:
    kelz33 likes this.
  5. Apr 5, 2016 at 6:03 PM
    #5565
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    Zip ties!
  6. Apr 5, 2016 at 6:11 PM
    #5566
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    No holes close enough :( would you trust velcro?
  7. Apr 5, 2016 at 7:37 PM
    #5567
    1stgen
    18 SR5
    I personally don't. What I'd do is probably double sided 3m tape for the cleanest look.
    Edit: just press down and make sure both surfaces are clean.
    Scoobarooo[QUOTED] likes this.
  8. Apr 5, 2016 at 8:14 PM
    #5568
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Yeah and I tried checking the box for file transfers and photo transfers. Nothing worked. I ended up reformatting the card for internal storage rather than portable storage. Haven't tested it to see if it's going to work yet.
    SpruceTaco[QUOTED] likes this.
  9. Apr 6, 2016 at 11:30 AM
    #5569
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    So. This just happened.
  10. Apr 6, 2016 at 11:31 AM
    #5570
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Oh fuck! sorry to see that man, what happened?
  11. Apr 6, 2016 at 11:31 AM
    #5571
    Taco No Baka
    Lee
    Tampa, FL
    holy shit, dude! You alright?
  12. Apr 6, 2016 at 11:32 AM
    #5572
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    This girl was making a left turn into a plaza and she said the car sitting there waved her to go. So she pulled out in front of me while I was going 45. And yeah, no good.
  13. Apr 6, 2016 at 11:33 AM
    #5573
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    I'm fine, I'm sitting her right now while my girlfriend gets checked out at the hospital.
    k9cop likes this.
  14. Apr 6, 2016 at 11:35 AM
    #5574
    kelz33
    kelz33 Active Member
    2013 toyota tacoma trd
    Dammmmmmn man
  15. Apr 6, 2016 at 11:35 AM
    #5575
    Taco No Baka
    Lee
    Tampa, FL
    Hope she's okay. The Taco is probably done for though. :(
    Just replacing the airbags alone will probably exceed the worth of the truck unfortunately, let alone the rest of the damage. :(
  16. Apr 6, 2016 at 11:35 AM
    #5576
    Soul Surfer
    Jimi
    ‘25 TRD OR
    That Totally Sucks Casey!! Hope your weren't hurt Bad!
  17. Apr 6, 2016 at 11:39 AM
    #5577
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Believe it or not the airbags didn't go off... And I don't know why. But I'm sure the truck is done.
  18. Apr 6, 2016 at 11:41 AM
    #5578
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    The oils on the ground, radiator got punctured, glove box doesn't close, control arm I think is bent, the support beam below the hood is bent to crap. Headights, grille, bumper, crash bar, it all history.
  19. Apr 6, 2016 at 11:55 AM
    #5579
    Taco No Baka
    Lee
    Tampa, FL
    Wow, that's not good. You could probably make an issue of that if you guys are injured at all.
    I feel for ya, Brah, that was a clean 1st Gen DC. On the bright side, you might be able to replace it with a 4WD Taco.
  20. Apr 6, 2016 at 11:59 AM
    #5580
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Damn that really sucks, sorry man!
