Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Apr 6, 2016 at 12:01 PM
    #5581
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Yeah, that's true.
  2. Apr 6, 2016 at 12:03 PM
    #5582
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    And no idea what hit the windshield but it was either my girlfriends head or her phone.
  3. Apr 6, 2016 at 12:07 PM
    #5583
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    :eek:!?! She was wearing her seatbelt, right? :confused:
  4. Apr 6, 2016 at 12:09 PM
    #5584
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    No she was not. So I'm very very glad she came out the way she did. It could have been much worse.
  5. Apr 6, 2016 at 12:09 PM
    #5585
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    This was my son's truck after he tried to take on a tree & lost. It was over $10k in damage but included a complete respray due to a lot of scratches from tree limbs. It was totaled. :mad: :(
  6. Apr 6, 2016 at 12:13 PM
    #5586
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    Glad you guys are ok man. Definitely could have been way worse. Sorry about the truck. I feel for ya. Always thought you had a clean 1st gen.
    Scoobarooo[QUOTED] likes this.
  7. Apr 6, 2016 at 12:18 PM
    #5587
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Why thank you sir. Hopefully I can make it clean again.
  8. Apr 6, 2016 at 12:21 PM
    #5588
    Taco No Baka
    Lee
    Tampa, FL
    o_O Well, shit. I sincerely hope she considers this a wake-up call. As uncomfortable as the seatbelt might be, it's a lot more comfortable than putting your head through the windshield. Hope she's okay. :fingerscrossed:
    kelz33 and Rattletrap66 like this.
  9. Apr 6, 2016 at 12:59 PM
    #5589
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    She usually does wear her seatbelt. Bad timing, but yes... I'm sure this is certainly a wake up call.
  10. Apr 6, 2016 at 5:18 PM
    #5590
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Pulled the light bar off the mangled front end.. Is this fine to be used all bent up like this? I have one extra mount for it. I'll have to buy another one.
  11. Apr 6, 2016 at 5:19 PM
    #5591
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    No pic
  12. Apr 6, 2016 at 5:22 PM
    #5592
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Weird. Shows up on mine.
  13. Apr 6, 2016 at 5:25 PM
    #5593
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    It didn't show up & I even refreshed the page. It's there now.
    Those fins might not matter but you bracket are pretty twisted. You can probably take them off & beat them back into shape. Does it still work?
  14. Apr 6, 2016 at 5:25 PM
    #5594
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    I have no clue. Nothing to hook it up too haha
  15. Apr 6, 2016 at 5:26 PM
    #5595
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Directly to your battery, if it's ok that is.
  16. Apr 6, 2016 at 5:27 PM
    #5596
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Hood doesn't open
  17. Apr 6, 2016 at 5:28 PM
    #5597
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Oh yeah, didn't think of that. Haha
    What about your girls car?
    Hugopreston likes this.
  18. Apr 6, 2016 at 5:28 PM
    #5598
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    As am I, hopefully it'll be revived though. I'd prefer not to get rid of this truck. And yes! Her X-rays came back all clear. Did you get those pods finally?!
    kelz33 and Soul Surfer like this.
  19. Apr 6, 2016 at 5:29 PM
    #5599
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    It's probably dead. Her transmission went out a while ago and it's been sitting ever since.
  20. Apr 6, 2016 at 5:29 PM
    #5600
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    He won't come over, I even invited him over. Haha
    White Horse likes this.
