Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Apr 16, 2016 at 7:35 PM
    #5801
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    It's a small alpine sub that I have strategically zip tied under the glove box.
  2. Apr 16, 2016 at 7:36 PM
    #5802
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Oh god. I want mine screwed to the rear wall behind the back seat, I think it's too big though.
  3. Apr 16, 2016 at 7:37 PM
    #5803
    1stgen
    18 SR5
    Good luck. I got a small one just for that reason but I'm pretty sure it doesn't really do much.
  4. Apr 16, 2016 at 9:17 PM
    #5804
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Wiring isn't that bad.
  5. Apr 16, 2016 at 10:36 PM
    #5805
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Haha, I'm kinda the same way, although Rick guilted me into helping him start his HID mod. I got lucky though when it turned out that one of the halos broke loose and had to be sent back. Spruce helped him complete the project. :D
    Wiring sucks rancid, toxic-waste-filled pond water...full stop. Sure there's worse things, but wiring is about as bad as it gets and still be something I'll do for myself. That's why I didn't sign up for the Avionics department when I worked aircraft maintenance in spite of having the required licenses. I just absolutely loath wiring. :rant:
    If you like doing though, that's cool. If everyone was the same the world would be a boring place. :thumbsup:
  6. Apr 16, 2016 at 10:51 PM
    #5806
    Taco No Baka
    Lee
    Tampa, FL
    It's actually kind of ridiculous. I'm going to be running a bundle of 16 wires through the firewall for the switches, another 6 for the switch/dash light illumination, then the wires involved with 4 relays (4 wires to the fuse block, 4 to ground, 5 to accessories, not counting the 4 coming from the switches), plus 2 wires and a large fuse for the fuse block power supply, and one ground for the fuse block ground bus. A total of 38 wires to run a light bar, two pod lights, and a CB, although I am admittedly doing a lot of the leg work by pre-wiring for future accessories. Still that's a crap ton of wires.
  7. Apr 17, 2016 at 5:16 AM
    #5807
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    So when you gonna spill the beans!!!? :yay:
  8. Apr 17, 2016 at 5:23 AM
    #5808
    Timbo's Customs
    Timothy
    Lakeland FL
    Well now you have to spill the beans
    SpruceTaco likes this.
  9. Apr 17, 2016 at 5:25 AM
    #5809
    SilverJack
    SilverJack no one
    She seems nice, but a bit plastic. Low maintenance for sure. I would definitely not ask for a hand-job.
    White Horse likes this.
  10. Apr 17, 2016 at 6:12 AM
    #5810
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Oh yeah!! Good news guys, the truck isn't totaled and should be fixed within 3 weeks. And seeing as how the front end was destroyed, the entire front end is going to be brand spankin' new. So she's gonna look sharp.
  11. Apr 17, 2016 at 6:34 AM
    #5811
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    He did, read above :woot:
    Scoobarooo likes this.
  12. Apr 17, 2016 at 7:04 AM
    #5812
    Timbo's Customs
    Timothy
    Lakeland FL
    He posted after I did so how can I read what he posted?
    Scoobarooo and SpruceTaco like this.
  13. Apr 17, 2016 at 5:07 PM
    #5813
    Taco No Baka
    Lee
    Tampa, FL
    So...I woke up late today. Fully back on night shift schedule again. :pout: Almost didn't make it to the parts store for more wire. I got the big bundle made up and routed though. Had to route it twice because I wasn't happy with where it was the first time. It was running across a sharp metal edge and I concluded that was just asking for trouble. Much happier with it now and I think it looks pretty good (even if that was sort of the easier part). :thumbsup:
    Soul Surfer likes this.
  14. Apr 18, 2016 at 3:28 AM
    #5814
    Timbo's Customs
    Timothy
    Lakeland FL
    How many switches you plan on running?
  15. Apr 18, 2016 at 4:21 AM
    #5815
    LOUMO
    LOUMO Well-Known Member
    Bartow FL
    12 RegCab 4cyl 4x4
    OME full lift
    Who was the member on here that works at Wesley chapel Toyota? He is a salesman there?
  16. Apr 18, 2016 at 4:24 AM
    #5816
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    @Scooter WCT.
  17. Apr 18, 2016 at 4:25 AM
    #5817
    Timbo's Customs
    Timothy
    Lakeland FL
    @Scooter WCT he is on vacation right now
  18. Apr 18, 2016 at 5:25 AM
    #5818
    LOUMO
    Bartow FL
    12 RegCab 4cyl 4x4
    OME full lift
    Well that is no help lol I am kinda in a jam and wanted to ask about an option I might have.
    kelz33 likes this.
  19. Apr 18, 2016 at 5:51 AM
    #5819
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    You could read what he posted after what I posted which was after what you posted but before this post which is after your post
  20. Apr 18, 2016 at 6:08 AM
    #5820
    Timbo's Customs
    Timothy
    Lakeland FL
    :bananadead:
