Tampa Bay Area Tacomas BS Thread
Discussion in 'Florida' started by Taco No Baka, Feb 9, 2013.
  1. Jul 13, 2016 at 5:32 PM
    #6821
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I would have guessed closer to 5k in parts, but you would know better than I would. ;) I also would have thought the crossmember would be the same so the IFS diff could be bolted right into it, but I wouldn't be surprised if I was wrong. :notsure:
  2. Jul 13, 2016 at 5:42 PM
    #6822
    Doublemind
    Doublemind Well-Known Member
    Well I'd like to just accomplish the 2wd to 4wd before considering the solid axle even if I end up changing some parts. I would like to keep it electronic if possible by using an actually Tacoma t-case. Ill pay for the 4x4 ecu and harness.
  3. Jul 13, 2016 at 5:45 PM
    #6823
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    A better option would be to get the prerunner adapter from Inchworm so you can keep your stock 2wd transmission and just run a manual shift FJ transfer case. The price would be up there, but so would getting a 4wd transmission and transfer case. The adapter would make the swap a hell of a lot easier too. Less electronic stuff to deal with as well.
  4. Jul 13, 2016 at 5:45 PM
    #6824
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    It's very possible, depends on what you can find at the junkyards.
    The transmission crossmember is what I meant, sorry, I should have clarified.
  5. Jul 13, 2016 at 5:48 PM
    #6825
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Well by God, I might be able to help you out there.
  6. Jul 13, 2016 at 5:49 PM
    #6826
    Taco No Baka
    Lee
    Tampa, FL
    Haha, either way, really. Don't you have an FJ case you were looking to unload as well?
  7. Jul 13, 2016 at 5:50 PM
    #6827
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I've got one of each flavor and can make either one for an auto or MANual.
  8. Jul 13, 2016 at 6:28 PM
    #6828
    Doublemind
    Please do, I'm ready to make this happen asap
  9. Jul 13, 2016 at 6:40 PM
    #6829
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    @ajohnson did it but he already has a 4runner straight axled on 40s
  10. Jul 13, 2016 at 6:40 PM
    #6830
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Wut
    The End likes this.
  11. Jul 13, 2016 at 6:48 PM
    #6831
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I only have a transfer case, I parted all my 4wd stuff out a while back.
    What I would do is call these guys at Morrison auto, 608-561-5031. I dealt with a guy named Alex. I found them through RST, the shipped the transfer case on a small pallet right to my front door. Tell him everything you need and also check the local junkyards.
  12. Jul 13, 2016 at 6:52 PM
    #6832
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    If i had a 2wd and wanted to go 4wd i would definitely go solid axle d44 with an adapter behind a prerunner trans, would be cheaper, easier and stronger.
    Is that your only vehicle?
    Taco No Baka[OP] likes this.
  13. Jul 13, 2016 at 7:02 PM
    #6833
    Doublemind
    If that route still got me the end result which is going 4wd I'd be all for it. I would need to know exactly everything to buy for that.
    No it's not my main vehicle.
  14. Jul 13, 2016 at 7:13 PM
    #6834
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I'm on night shift so I'll hang around for a bit.
    What is your goal for the truck, what kind of offroading do you plan on doing and most importantly, honestly, how much can you budget have you already set money aside? How long can you be without your truck?
    Rattletrap66 likes this.
  15. Jul 13, 2016 at 7:15 PM
    #6835
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I'm also curious as to how old you are and what do you do for a living, no homo.
  16. Jul 13, 2016 at 7:18 PM
    #6836
    Doublemind
    30 and small business owner
  17. Jul 13, 2016 at 7:21 PM
    #6837
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Ok, do a solid axle with a manual case and hubs then you won't have to mess with any of the electronics.
  18. Jul 13, 2016 at 7:28 PM
    #6838
    Doublemind
    Well I rather keep it closed to stock, because my offroading will be minumal. So any chance you have part numbers to the parts need, Or are the parts needed exactly the same on any 05-14 Tacoma? Someone mentioned getting an adapter plate which I will do so I don't have to change out the transmission.
  19. Jul 13, 2016 at 7:30 PM
    #6839
    Doublemind
    Well how's the ride in a solid axle car rather then keeping it oem with the electronics :-/
  20. Jul 13, 2016 at 7:36 PM
    #6840
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    And I spent two years collecting the parts, and a month DD'ing the tin can GlamRunner during the conversion. It didn't happen overnight lol.
